Using the formula for the required intake valve diameter needed for peak Hp to occur..
Intake Valve Diameter = ((RPM*CID)/(Cylinders*306.7*282.7433388))^.5
My question is..Has anyone ever tried to use a smaller valve in a 2v or 4v cleveland head..intended to peak Hp at 7000 rpm..
Do you think,(taking into consideration the combo is to suit),that with the size valve,say for the 2v would be around a 1.950-2.000",would the car accelerate harder than with the 2.04" valve..It certainly does for the chevs..I realise that the port design differs,as does the port velocity gradient...I was just wondering if anyone has ever tried this...Because with the cleveland,if you intend to only rev to 7000-7500rpm,then the valve could really be a little smaller?It would certainly help to get the clevelands port velocity gradient a little more even,and drop the volume vof the port a little, perhaps to be more where it should be for this 7000 rpm peak?
