Anyone have any experience with these?
MadBill wrote:Of course, if you have a big enough shop to justify the inventory, you can have one (or two) of every spacer known to man on the shelf, and run all the likely suspects across the engine on the dyno, then just sell the customer the version that works best for his app.
Tech @ BG wrote:There are pros and cons as with any spacer. If the intake tract is engineered properly you shouldn’t need a spacer in the first place. A spacer is a great tuning aid to adjust the power-band, or to make up for a mismatch in parts. It’s not always practical to design an intake, cylinder head, carburetor, cam profile for each application you may be able to use commonly available components and with the addition of a spacer get the performance you’re looking for.
As far as how well any spacer will work it’s a matter of what the combination requires. I’ve seen as much as 28 hp increase with a spacer change. The engine builder was so excited he wanted to put the “good” engine on the dyno which was up about 50 hp from the other, installed the new trick of the week spacer that just made 28 hp more on the last engine and it did nothing. Looking at the graphs you couldn’t even see that a change had been made.
As far as the merged spacers, they have merit, however I believe it’s a matter of how it will work with the specific intake manifold and engine signal. If you had the ability to build a merged spacer specifically to each intake manifold then you should be able to see something there.
Users browsing this forum: Baprace, Blacktrack, GregGood, racerx1622, SKeown, Sprinter99 and 5 guests
