Lots of parts
In-Tech
Lots of parts
Post by In-Tech » Fri Jan 17, 2014 2:38 pm
Hi Folks,
Cleaning up shop to free up some cash to buy other things I want :) . I think the prices are fair but any offers received via pm will be looked at. I'll email pictures upon request. All items are PLUS freight. I'm in central California.
14-71 Alcohol Kuhl std helix mag case with drive and pulleys(56/60 8mm) 6 passes since freshened by The Blower Shop and has their billet front cover. $2000
New Mahle pistons and rings, the expensive ones with the vertical gas ports 4.035 x 1.250ch 12 cc ASCS dome, 1.1/ 1.1/ 3mm . $800
Pistons Catalog number 0936914135, rings 4040ML-043 4.035 + .005
Whipple 1.6 L rear entry blower, excellent like new shape. $800
Vortech S-trim blower, less than 4 hours on it, went to T-trim, excellent shape. $800
Brodix -11 ASCS heads, fresh valve job and surface, new roller springs, was on alcohol. No porting. Complete but had T & D's therefore no studs/plates $1000
Holley Alcohol 750 List # 80535-1 Perfect shape $350
LA Enterprises Kryptonite SBC crankshaft. Ultralight scalloped design. 3.500" stroke STD/STD BW 1647 seems I remember it right at 40lbs $1000
2-sets of 16 Crower Aluminum Roller rockers SBC 1.5 ratio .150 offset in & ex. Perfect shape. Went to Jesel $200 set of 16
2-Erson Solid Roller SBC cams. .400" lobe 247/259 114LC Very easy on valvetrain, good street nitrous/blown or marine. Perfect shape $100 ea
New Painless wiring TBI harness #60101 $200
Rochester 17090304 36# injectors High impedance, just cleaned/flow tested 2 weeks ago $200 set of 8
Siemens 3102 57# low impedance injectors, will clean/flow test before shipment. $250 set of 8
-Carl
In-Tech
Re: Lots of parts
Post by In-Tech » Mon Jan 20, 2014 9:33 pm
14-71 Sold
-Carl
r2dudes
Re: Lots of parts
Post by r2dudes » Thu Jan 23, 2014 9:17 pm
sent you a PM
In-Tech
Re: Lots of parts
Post by In-Tech » Fri Feb 07, 2014 3:23 pm
Painless TBI wiring harness sold. Thanks
Also, correction, the Mahle pistons have the lateral gas ports, NOT vertical. I just re-read the ad and noticed that, sot sure what I was thinking #-o
-Carl
In-Tech
Re: Lots of parts
Post by In-Tech » Fri Feb 07, 2014 3:26 pm
In-Tech wrote:Painless TBI wiring harness sold. Thanks
Also, correction, the Mahle pistons have the lateral gas ports, NOT vertical. I just re-read the ad and noticed that, not sure what I was thinking #-o
-Carl
In-Tech
Re: Lots of parts
Post by In-Tech » Wed Jun 18, 2014 2:00 am
Ttt
All injectors sold.
-Carl
paul8
Re: Lots of parts
Post by paul8 » Wed Jun 21, 2017 4:53 pm
Hi,
I found your older announcement with different parts. There were also Rochester injectors 17090304.
I am looking for few of them. DO you know cross reference and what is the fuel flow of these injectors?
Thank you!
In-Tech
Re: Lots of parts
Post by In-Tech » Thu Jun 22, 2017 4:47 pm
That is the only part number I know for them. They are ~36lb @ 43psi and ~42lb @ 58psi
-Carl
