beth wrote:It would be 4 valve, with about 6 degree valve angle, slight pentroof, small centrally located spark plug. 4 squish areas along with a 360 degree squish band. Intake ports as physically high as valve material and length would allow. 2 intake and 2 exhaust ports per cylinder and about 5 years to perfect it.
#84Dave wrote:If I personally had right at $337K I didn't know what to do with, I'd build a 5-valve/500"/quad-cam Pro Stock. SAE papers abound that show 3 intakes and 2 exhausts afford the greatest valve area possible inside a pent-roof chamber. With 1.8:1 finger-followers, 105#/120# seat pressures on titanium intake/exhaust valves, the valve train would be 'quiet' until just short of 12,000. Take the 'Stock' out of 'Pro', have fun racing and welcome to the 21st century.
Dave
Something that engines like the YZF750SP from Yamaha will tell you just from looking at the race spec ignition box' specs... from 7000 rpm on,you're running 50+ degrees of ignition. Still doesn't knock though...Justin Jones wrote:5 valve is losing it's popularity, It might flow gobs of air but you can't make a 5 valve chamber burn very good like a 4 valve....
SchmidtMotorWorks wrote:I have lost track of motorcycle heads, have any of them gone to finger followers?
If I could do anything to a head I would make rotary valves
powered by pure hydrogen and oxegen derived from an on board water source
Users browsing this forum: Baprace, Blacktrack, GregGood, racerx1622, SKeown, Sprinter99 and 5 guests
