beth wrote:Flame propagation speed changes with engine design but it also changes with RPM and load so I'm not sure there is an answer.
moper wrote:After reading that article..Now I have a question. He refers to "squish area ratio" in it. Is this a volume measure of the squish area over total cylinder volume, or over cumbustion space volume? I Have read about the "lines" being ground into the head side over a quench area. It was thought this gave the flame front a path to any mixture in the quench area. Is it possible these lines simply add to the squish area volume, thus increasing the rate of burn, as opposed to getting a better burn and more heat from the small amounts trapped in the squish area? Or am I way off base?
Darin Morgan wrote:… A Pro Stocker has a ratio of about 45%. That’s extremely high!... … We don't use all of it or keep it perfectly flat. We utilize all of it to our advantage by modifications to the squish pad or piston in order to manipulate the air fuel mixture in such a way as to accelerate the deflagration process.
That’s a fancy way of saying we point the air fuel mixture to the center of the chamber over the spark plug so we burn it faster, cleaner and make more power. The idea is to get the majority of the air fuel mixture over the plug and have it very agitated. We accomplish this by manipulation of the chamber, squish quench pads and piston dome design.
Rod Rocks wrote:Darin Morgan wrote:… A Pro Stocker has a ratio of about 45%. That’s extremely high!... … We don't use all of it or keep it perfectly flat. We utilize all of it to our advantage by modifications to the squish pad or piston in order to manipulate the air fuel mixture in such a way as to accelerate the deflagration process.
Darin,
If I understand what you are saying your piston and head modifications help to direct homogenized squish flow into the area of the plug where it will best promote combustion. This is a turn from what I’m accustomed to that being two flat surfaces coming together forcing the mixture laterally into the chamber cavity.
Can you give specifics on modifications required to get the majority of the squished mixture into the central portion of the chamber cavity near the plug?
Users browsing this forum: Google [Bot], Sprinter99 and 4 guests
