Easiest Way To Pull Press-in Rocker Studs W/O Special Puller
I need to pull a few press-in rocker studs on an old set of heads that have gotten pretty grooved by the rocker arms over the years.
I'd prefer not to buy a special puller if I don't have to since most everything I work on has screw-in studs.
Just wondering what methods others have successfully used to do this w/o a puller?
Does tightening down a nut on a stack of washers or washers with a socket work? Does heating the stud boss on the head first help?
Thanks.
Thanks.
- Wolfplace
Re: Easiest Way To Pull Press-in Rocker Studs W/O Special Pu
Yes to the first questioncoollx wrote:I need to pull a few press-in rocker studs on an old set of heads that have gotten pretty grooved by the rocker arms over the years.
Thanks.
No to the second
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
- Eric David Bru
The washers wor, but you can buy a puller for just a few bucks on eBay too.
http://cgi.ebay.com/Rocker-Arm-Stud-Ins ... dZViewItem
Re: Easiest Way To Pull Press-in Rocker Studs W/O Special Puller
If you're a typical homeowner, a short piece of 3/4" water pipe from your 'possibles' pile and a big washer works fine, at zero cost and 10 minutes of hacksawing.
You need something stout under the nut, rocker balls are perfect.
A good nut like off a rodbolt will be beneficial to.
When you experience how tight they are in there, you'll understand why they don't pull out in operation.
- Dave Koehler
Agreed. Rocker balls and rod nuts for the budget win.
LOL,revived an 18 year old thread. LOL!!
What the hell I'll add to it,use a good lube such as ARP lube or moly paste on the threads.
