F-BIRD'88 wrote: have a cam in mind for you. It is a UD Harold Cam. (Ultradyne) UD Harold is the right guy to talk to
about this cam and your motor. It is not a custom cam. It is a off the shelf cam. But Harold may want to adjust it.
He is a cam expert and this is his cam. 11.12:1cr is plenty compression for this specific camshaft.
It took a little while but I did get a response to my cam enquiry from Ultradyne.
With 11:1c/r..
@.020" = 289/295°
@.050" = 259/265°
lift = .731"/.731"
lobe sep = 108°
With 12:1c/r..
.020 = 291/297°
.050 = 261/267°
lift = .731/.731
lobe sep = 108°
both cams lash @ .020/.022"
Crane 138801 that I have "in hand"..
(no duration info @.020")
@.050"=262/272°
lift = .714"/.714"
lobe sep = 106°
I would like to know where the Crane cam is too small and how it is the wrong cam as Ultradyne's recomendation is similar (slightly smaller) and only has a tad more lift (+0.017"). Lobe seps are about the same with the Crane's 106°being better with this heavy car, I dare say.
I asked for a 12:1 recomendation to kind of compare apples with the existing Crane, but I have decided not to go 12:1 with this rebuild, and to remove the water injection.
I'm not 100% sure what the end c/r will be but it will be around 11:1. It just depends on what pistons I end up using -hopefully my existing custom Ross'.
DCR with 11.15:1 is around 8.5 using the Crane cam. I assume that 8.5 will be OK on pump fuel, or is 8.5 boarderline? Should I drop it a little more to be safe?
