I have another post in here from a few weeks back.
#2 plug looks lean, and has in normal driving.
What I did, after much troubleshooting and expeimentation, was richen the IFR slightly, close down the idle air bleed from .073 to .062 and then closed the idle screws to get a clean idle
What this did was allow the transition fuel to come on a little harder and be a little richer at 1000-1500
It idles good, runs pretty good, but still bucks a little at very low rpm. Before richening transition fuel, it bucked HARD with any carb at 1800-2000, now its livable, but not right, with a buck at 1000-1400 or so
I have gone through all the normal tuning, vacuum leak checks, manifold checks, etc. This thing just loves a lot of transition fuel and I dont know why
My theory is that #2 isnt getting fuel at very low RPM and by fattening it extremely, I am bandaiding it
I have reviewed literally 40+ dyno sheets of various FEs with the RPM intake and EVERY ONE has a dip in the torque curve at some point between 1500 and 3000 depending on how its configured.
I think it has to be the manifold, but my alternative doesnt look like it will feed the motor, so I figure with some thinking, I can port the single plane to do what I need it to do
Take a look at the dip on this older Edelbrock test (scroll to the bottom, 2 charts)
As a rule, the bigger the motor, the lower the RPM for the dip, but from 390's to 511 FEs they all show a dip in the torque curve, look at the drop at 3500 It doesnt bother some guys, they shift around it, but as a street car its a pain. This one is 50+ cubes less than mine, which could account for the dip being higher, but just the same, it exists on every graph I have seen with an Edelbrock RPM on an FE Ford
http://www.edelbrock.com/automotive/sto ... omber.html
FYI it is an unheated manifold, and at initial fire up it seems better. Once it reaches temp it seems more prevalent (which seems backwards to me)
