rewguy wrote:If the equation holds true........
FPS = (bore x bore x stroke x RPM (of peak hp) x .00353) / CA
that equates to 732 fps wich is WELL over mach .55 if you use 4.03 as a bore size, 3.48 as a stroke, and 7200 as a peak hp rpm, and 1.96 as a min CSA. I know some of these numbers I used are off of what a superstock 360ish cube is....But arent they kind of close? If so......how are you making peak hp so high if the fps is over 700 with this equation? Im sure Im missing something, but I thought Id ask.
timdog wrote:What happens to CSA/FPS calculations when you have a 4-valve (or more!) per cylinder head?
Is it worth looking at the minimum CSA point to calculate FPS at this point? I have tried various different ramp profiles on the ports along with different size minimum CSA's, all having the same average CSA and seen quite different results.
If you were to look at minimum CSA then would this be twice its value for a split port?
Sorry if question sounds dumb, its been a long day and i'm struggling to write what my feeble brain is trying to say ......
CMI Motorsports wrote:Larry,
The number I have been using is 614fps when I want to calculate minimum CSA. I think I got that number from a previous post. Is that what you recommend?
I also read that SAE technical paper(Japanese automaker![]()
) that for engines with limitations on CSA relative to their stock castings and large bore and strokes, that duration is the way to exceed .55 Mach. Can you speak to those of us that have intake ports whistling Dixie above 0.55?
Lynn
shawn wrote:I could be wrong, but I don't think he's actually refering to the port making a whistling noise, but asking what to do with a port that has exceeded .55 mach in running conditions without having any cross section left. Much like you have with a super stock style drag head.
Shawn
larrycavan wrote:How closely does this formula work out to your actual data?
Intake Runner Area = Cylinder Volume X Peak Torque RPM / 88200
Why would I be interested in peak torque? Our cars always perform better running off of peak HP. My peak torque is 4800 RPM, and the car never sees less that 6000 RPM down the track. Anytime we cram the motor down, the car slows down.
We have been doing tons of work on acceleration values. I believe that due to the "choke" of the intake ports our engines work very well at low accelerations rates 300 RPM/Sec and below. When we cram the motor down, we are asking the engine to accelerate the car.
Lynn
Users browsing this forum: Baprace, Blacktrack, gmc406, Google [Bot], IDEALER, SKeown, Sprinter99 and 4 guests
