I am parting out a Small Block Chevy 408 CALL OR TEXT 801-661-1511
It has only 2 HOURS RUNNING TIME
Short Block 1750.00
GM 509 Block
Studded Mains
Internally Balanced Scat Forged Rotating
assy. SRP Forged Flat Top Pistons.
11.6 to one Compression Ratio
Comp Cams 2 Piece Billet Timing Cover
Melling Oil Pump
Felpro Gaskets
Moroso Kick out Oil pan
Professional Products Damper
SFI Flex plate
Profiler 210 cc heads 64 cc Chambers. 1050.00
2.08 Intake Valve. From Speier Racing
Flow better than AFR 210cc heads
Hydraulic Roller Double Springs 135 ft-lbs
Springs
Comp Cams Hydraulic Roller XE294 HR 225.00
242/248 @.50 .576/.600
Howards Hydraulic Roller Lifters 300.00
Trick Flow .80 Wall Chromoly Push Rods 75.00
Dove 1.6 Roller Rockers 150.00
Aluminum Water Pump 50.00
Edelbrock RPM air Gap Intake 125.00
Trick Flow Valve Covers 100.00
K&N Air Filter 50.00
Hedman Ceramic 1 ¾ Headers 69086 300.00
Parting out Chevy 408 SBC Roller Cam, Forged
- ItalianJohnny
