The car felt a lot of stronger, but he lost ~40hp in dyno.
67RS502 wrote:There are reasons why a car may pick up power with or without mufflers,
one may be what type of muffler is being used, and where its placed.
We need to first figure out whats the optimum exhaust system (headers back)
for the given combo is. Usually its a header extension, where the length is
the important factor. So lets say this engine makes the best power with
a 3 1/2" dia. x 18" lg. extension and no muffs. Now stick it in a car, where
an exhaust system is needed, and you may not be able to get a H-pipe or
X-pipe 18" behind the collectors. Now you have to compromise and will loose
some power if you have to put in 2-3ft of pipe behind the collectors to get
a H-pipe, X-pipe or something with some (plenum) volume in it. But on the
other hand if you can stick 18" of pipe and behind it have "chambered" mufflers
with some volume, the engine may see no loss as long an the pipes and muffs are
large enough, say 3 1/2", since this set up very closely resembles the open
header / 18" extensions that were used on the dyno.
Adrenaline_Z wrote:According to Vizard, and some other tuning sources, any reflective surface
or abrubt change in the secondary piping should be placed where the
tuned length of the collector ends.
In other words, if the collector length makes best average power at 18 inches,
place the muffler at that point.
MadBill wrote:<EDIT> I would have posted mine first, Adrenaline, except I accidentally blew away my first attempt...![]()
I would make an educated guess that a glass or steel pack would extend the effective collector length to about halfway down the core. I also suspect that it would not provide the same scavenging effect as an open header, since the pressure pulses would be dissipated in the core, rather than reflected from the open end as a negative.
Also, with the exception of Borla and a couple of others, most glass packs are pretty restrictive. If the core isn't larger diameter than the end fittings, or there are big louvres hanging into the flow path, look eleswhere...
Users browsing this forum: Baprace, Blacktrack, gmc406, Google [Bot], IDEALER, racerx1622, SKeown, Sprinter99 and 5 guests
