mounts alternator at mid height on the passenger side of the block, requires a shorter belt and helps to reduce belt throwing. Weighs 1 pound less than the factory bracketry. Laser cut from 1/4 mild steel. For long water pump, short deck BBC applications only. Actual bracket is a little different than the picture in that there is a couple lightening holes near the bolt holes. $40 shipped anywhere in Canada or USA. Cash, cheque, money order or paypal to brianj_taylor@hotmail.com
thanks
Uses the factory spacer between the alternator and the head.
BBC laser cut alternator bracket
Re: BBC laser cut alternator bracket
bump
