PWMAX wrote:I have seen similiar stuff on some raised runner pontiac/chevy 23 degree heads, for an old superstock, now comp combo. 340ish cubes. Single 4, sheet metal deal. Heads were done by Bud Harper. That side is epoxied in, very similiar, the port is ported into a semi oval shape on the roof, and epoxied into an oval shape on the floor. The front of the guide is also mudded up, to direct the air. The motor in question, makes 740 hp or so, and turns about 10,000 rpm. I know before the mods, the motor made similiar power, maybe a little more. The guy is changing and trying stuff a lot, so, its hard to say, if that work really helped, or not. It will definately speed up the velocity over the short turn, and direct the air more towards the center of the cylinder. My personaly opinion, is, I thinks its a band aid, "trick of the week", to soak another $1500 out of the guy.
Frank
ccb wrote:It looks like an old set of plate heads when nascar ran 18 deg heads.Petty's were running that style in there engines.
Dan Barton wrote:Have seen this type of thing many times before from Harper and some others, I believe this is what you get when you port and only look at flow bench numbers, have also taken it out and improved power and the engines seem to accelerate better, my experience with swirl is it can get you into trouble with to much being wasted energy that could better be used by filling the cylinder.
Max Effort wrote:It seems that these swirl ports have come and gone in the OEM heads too.
So why are these designs such a "dud"?
I agree with larry, about the swirl deal. Where, you gain swirl, and loose a little flow, and, the car runs the same. One dynamic is making up for what the other lost. Gm had them in the ls1 heads originaly, or something similiar, that, you were always told NOT to touch, EVER, no matter what. Well, when you did, what ever they were on, loved it.
Users browsing this forum: Baprace, Blacktrack, gmc406, Google [Bot], IDEALER, racerx1622, SKeown, Sprinter99 and 5 guests
