airflowdevelop wrote:...I don't know how in todays world, you could live without a WB02....
Dennis
airflowdevelop wrote:Why do you say interesting?
I have used many of the cheaper boxes with good results, including the innovate, even with injected alcohol.
What do you want to know?
Dennis
If you have any additional questions, feel free to ask. Nothing wrong with the innovate or tech edge. If you would like it calibrated, I have a LAB-1 for calibration, if it is that critical for your app.
Dennis
airflowdevelop wrote:[The first 50 years was relatively easy, it's the next 50 that concerns me. What's a good low buck unit? Any tricks to make the O2 sensor last?
Tech @ BG wrote:The Innovate units are Great for the money.
They can really help dial in a combination especially when you're working on drivability issues. We use a number of different systems, and the innovates are extremely accurate, and last as well if not better than most other units.
automotive breath wrote:Tech @ BG wrote:The Innovate units are Great for the money.
What a/f ratio change can be expected with a jet change of one number all the way around?
Tech @ BG wrote:...It will vary depending carburetor sizing, tune-up, and engine. On most applications 1 jet size is worth about 4 lbs/hr when tuning.
automotive breath wrote:Tech @ BG wrote:...It will vary depending carburetor sizing, tune-up, and engine. On most applications 1 jet size is worth about 4 lbs/hr when tuning.
Stick with me on this one; maybe if you helped me with the math I could understand the concept.
I have a 355 SBC with a 750 SCFM carb; jets are 82's square with no power valves. The RPM range is 5500 to 7500. Approximately what is my AFR and what would it be with 81's square
Users browsing this forum: crumple, Sprinter99 and 12 guests
