lil289 wrote:Since this contest was designed around streetable motors - 2,500-6,500 RPM's, fuel economy might be a concern here. Not the primary one obviously but a concern nonetheless. What good is a street car if it makes big power but sucks so much gas that it winds up sitting in the garage most of the time? Besides, the competitors are coming out with such creative ideas that it would be interesting to see if some oddball design, while not making that few extra percentage points of power for the win, might be a lot more fuel effiecient. I'm sure the OEM's would be interested in this sort of data too. What do you think?
OldSStroker wrote:The BSFC numbers would be good only for wide open throttle (acceleration) operation. They would have very little to do with part throttle cruising. If the builder decided to jet a little rich to help keep from melting down the pistons, BSFC would be higher for similar power.
rmcomprandy wrote:They don't post 'em because they're terrible; using extra fuel to squelch detonation with the 91 octane they're required to use...! The exhaust temps are way high with high compression ratios 'cause the gas is still burning in the pipe even with short duration cams.
This year they've limited the compression ratios to a maximum of 10.5/1 so, it will probably be different.
SStrokerAce wrote:I have the Superflow files for Shermans winning runs for 2002. I'm not sure how accurate Westechs stuff was but the BSFC was .273-.387 during the pull, with corresponding A/F ratios of 17.3-13.9:1
Bret
putztastics wrote:SStrokerAce wrote:I have the Superflow files for Shermans winning runs for 2002. I'm not sure how accurate Westechs stuff was but the BSFC was .273-.387 during the pull, with corresponding A/F ratios of 17.3-13.9:1
Bret
Bret, anyone, do you believe the .273 BSFC and 17.3 A/F ratio are accurate?
Users browsing this forum: Baprace, Blacktrack, GregGood, racerx1622, SKeown, Sprinter99 and 5 guests
