Darin Morgan wrote:First off, I don't know the EXACT clearances that the NASCAR engine builders use so I will have to check on that. I do know that there average operating temperature is way above what a drag race engine SHOULD see and in this case I can see the clearances tightening up a little but due to component expansion but I don't think its whole lot. I will have to call some of my engine building friends over there and ask. I also see why there oils wont/don't/cant make power in a drag racing engine. We have tested all there high dollar oils that where specially formulated for them. Some costing in the $30.00 a quart range. They all failed miserably in the power department. There oils are formulated for extreme temps above 200+F and have additive packages to withstand stresses for extended periods of time. Anyone who takes a Drag racing engine over 140F at launch needs to have there head examined! (personal opinion)
The main and rod diameters we use are stock BBC and SBC and the Pro Stock engines have a 1.880rod journal a little over .625" wide and a 283 SBC main about .750" wide. Total bearing surface area in a P/S engine is about 20% less than a stock SBC.
If your looking at some preconceived clearance derived from the bearing diameter and surface area your missing the point. You cant scale the clearances up and down from a simple equation based on surface area and bearing speed. Don't take me wrong here, you must take into account the bearings surface speed and area but they are not the major factor in determining clearance. Factors yes, primary factor, no. You need to consider Internal component deflection and distortion when determining bearing clearance as well. We still routinely hone rods oval. Wider at the parting line than top to bottom. Why, because the rods distort under dynamic conditions and the parting line pulls in and wipes the bearing. When the bearing parting line touches the journal, BOOM out the side of the block it goes. We have had to oval Titanium rods .0075 at the parting line in order to make them live! Titanium has a very high modulus of elasticity in comparison to steal so the deflection and contortions of the rods big end had to be compensated for.
Why people think that there is something in having tight clearances is something I just don't understand?????
What possible benefit could you derive from shrinking the clearance down that last little .001 close to where the bearing seizes?????
Darin, all i can say is "I'm glad you Posted this first"
like your results , for the last 20+ years i've run nothing but
.0035" to .004" rod and main bearing clearances
on every Engine i've built, even my old Chevy Suburban Dragster Trailer Tow vehicle's SBC 406 cid has .0035"
never had 1 rod/main bearing failure yet in 20 years, not one !
Bearings look new -to- almost brand new after full season or more,
and most of time i never replace the main bearings, just new Rod Bearings instead on rebuilds.
all the Engine Builders i deal with run .003 to .004" Rod/Main clearances,
and most just tell Customers they have .002" to .0025"
(1) Get a good, professional machinist to line hone the mains and hone the rods properly.
(2) Make sure you have proper oiling. If your pressure fluctuates during the run,, you have problems.
(3) .003 rods and .0035 mains for clearance
(4) Use a good synthetic 05-30w oil like Mobil-1 or Castrol syntec
(5) In my personal opinion you need to stop using any oil from Amsoil. That is not a racing oil even if they say it is.
like you on the Amsoil,
i've never seen any HP/Torque gains.
Amsoil might be awesome "protecting" engine parts,
but as far as any gains in HP/TQ over other
similar weight oils, i've never seen any gains on my Dyno yet.
Mobil 1 and Castrol Syntec are very good oils as far as HP/TQ gains,
both are within 1 or so HP of each other on various engine Dyno testing i've done.
Royal Purple #9 is usually around 5 to as much as 12+ HP
more than Mobil 1 or Castrol Syntec
its been awhile since i last tested these Oils, formulations may change ??,
results may vary ?
