jcd wrote:According to my studies, later intake closing at high RPM will cause supercharging (yes, higher than 100%VE) because the incoming air at high velocity will want to keep coming in even though the piston has started coming back up. If the valve closes just as reversion begins to occur you have trapped more air than you would have at lower rpm, right? Thus your compression ratio is higher than the static compression ratio. Isn't this the theory of dynamic compression ratio?
Correct me if I'm wrong, going this heavy into the theory is new to me, but apparently this is what I need to learn to go faster...
My cam is Isky #OR-77. Intake is .020" from closed at 72* ABDC. It is .050" from closed at 54* ABDC. Compression is factory stock 9 to 1.
I turn about 7000 RPM.
femtnmax, where in MT are you?
Users browsing this forum: Baprace, Blacktrack, gmc406, Google [Bot], IDEALER, racerx1622, SKeown, Sprinter99 and 5 guests
