As a back up plan (or maybe regardless, just because enquiring minds want to know), I will twirl one with a big torque wrench...
Rick360 wrote:Wouldn't the amount of twist depend on which cylinder is firing?
You don't have even torque applied on all journals at the same time. When a front cylinder fires, the crank would twist more during it's power stroke since it is applying torque further from the flywheel. When a back cylinder fires it is so close to the flywheel there would be very little twist and the front cylinders would be taking power (pumping and compression etc) which would try to twist the other direction toward those cylinders. The total amount of twist would change a lot throughout 2 rev's. There could hardly be any "steady" twist, but there might be some consistent dynamic twisting that could be accounted for in timing of cam or ignition.
Rick
Ken_Parkman wrote:...effectiveness of the damper is probably the most important part of the crank twist story.
Users browsing this forum: 540 Vette, Baprace, gmc406, mustangmike68, racerx1622, Sprinter99 and 8 guests
