Increasing cfm can actually cost serious top end power (past 14k revs) without affecting power much below that. Port velocities are well over 350fps at 28" before the choke point.
A guy i know in the piston business reckons the current F1 engines use relatively small and high speed ports. He does supply a team with pistons but i have no idea if he giving me BS on the heads.
Another thing is the wave tuning on these engines is super critical.
Is anyone else working with these rpm and have any useful data that they want to share?
and did it with .050" lift on the cams using a shorter rocker ratio
from other thread=>
FPS = (CFM * 2.4 ) / CSA
if Head Flows 127 CFM at .200" Lift = 156.6 fps @ 1.948 csa
if head flows 260 CFM at .700" Lift = 320.3 fps @ 1.948" CSA
can the min csa be at the short turn opening to the bowl area or is it either the pushrod pinch area or valve seat choke area? also what mach index #s are you getting at 350 fps? thanks rob
timdog wrote:Interesting comments of the port choke position/place of minimum csa.
Here is a port reduction that gave mixed results.
Length is 3.75" and it would be very similar to data given earlier, although i seem to remember this had maybe slightly higher velocity again. Obviously the upper mold is the standard port.
The small port netted a 5% power gain at peak with a steady increase all the way from the start. The one thing it did struggle with was fuelling lower down up to nearly half way up rev range. Very bad pulsing i think. Was all over the place. Cleaned up at the top. It also straightened out the trough half way up the power band that normally you can't get rid of.
I've now moved this shape on quite a bit and its straighter on the bottom and top with a less agressive entry, but still a slight taper all the way. The point of minimum csa is closer to the valve stem too and slightly larger than shown here. This latest one does not suffer with any undue wave fuelling problems and has netted an 8% power increase over stock.
I definately agree that the port needs to open out again in preperation for the back of the valve and bowl area. Failure to do this robs power everywhere but more so up top.
larry,that makes total sense.do you think those high mach # heads were successful due to the total engine combo,especially cam profile? do you usually try to stop at .55 mach or what do you shoot for? how much effect does the valve lift & closing time have on min csa air speed? it seems to me that choosing a cam without knowing what & where your min csa is is somewhat of a crapshoot.is there a formula for figuring this out?----ProChamp
SS Chevy 362 cid 4.065 x 3.493 .013 Legal Stroker C-12 VP Race Gas
#041x 1.940/1.500 Cylinder Heads 165.0 Intake Port Volume
61.2 min Chamber Volume CC Q-Jet Carb Victor E Intake w/adapter
Cam Motion Solid-Roller Cam 1.635 Springs Flat Top BME pistons
3-Step Headers 1st= 1.750 x 14-15 2nd= 1.875 x 7.250 3rd= 2.000 x 8-9
3.500 Collectors x 16.250 long 34 deg to 36 deg BTDC .030 Lash
1.650/1.65 Rockers
made best of 585 Peak HP and 470 Peak TQ (600 RPM/SEC)
just about anytime of Year made 565 Peak HP to 575 HP with 465 to 470 TQ
at 3330 Lbs. 2-Speed PowerGlide
5800-6000 Stall, 5.86 gears , 14x32 Tires, 1968 Camaro
set NHRA SS/IA Record 10.132
incremental ET-Times
(when Engine made 565 HP 465 Peak TQ at that time)
60 FT= 1.330
330 FT= 4.058
660 FT= 6.377
1000 FT= 8.402
1320 FT =10.132
Dyno tested on SF-901 Dyno at 600 RPM/SEC
RPM---TQ----HP----Fuel Lbs
4500-449.5-385.1--166.1
4700-444.2-397.5--164.5
4900-455.2-424.7--177.0
5100-456.2-443.0--158.3
5300-464.1-468.3--169.6
5500-471.1-493.3--192.9
5700-470.2-510.3--199.2
5900-468.2-526.0--199.3
6100-465.0-540.1--204.5
6300-459.8-551.5--209.7
6500-456.6-565.1--216.3
6700-442.6-564.6--223.1
6900-432.8-568.6--217.2
7100-426.6-576.7--215.3
7300-418.3-581.4--224.5
7500-401.8-573.8--238.2
7600-394.1-570.3--231.0
it's kind of enlightening to now understand that.it brings to mind some of the bench racing stories of guys telling me about their 9000 rpm 283's.if they were doing that they had to bo sonic choked a few thousand r's before that.
SStrokerAce wrote:Interesting topic here.
Velocity_FPS = ( Test_Press ^ .5 ) * 66.2
Port_Velocity = ( CFM * 2.4 ) / Cross-Sectional_Area
FPS = ( CFM * 2.4 ) / CA
FPS = ( CFM / CA ) * 2.4
CFM = FPS * CA * .41666667
CFM = ( FPS * CA ) / 2.4
CA = ( CFM / FPS ) * 2.4
CA = ( CFM * 2.4 ) / FPS
I definately agree that the port needs to open out again in preperation for the back of the valve and bowl area. Failure to do this robs power everywhere but more so up top.---TimDog
steelcomp wrote:What would an intake runner look like for this type of port? Is this specifically for a short IR, or will it work with conventional cast intake/plenum designs?
maxracesoftware wrote:you have to be careful "using" or accounting for too much TAPER
that is,..if the TAPER is too great... you are seeing more effect
of "Shorter" Runner..you are effectively shortening up the Runner
..and it may not be the TAPER it likes , but the Overall Length
to some degree ??
Users browsing this forum: Baprace, GregGood, racerx1622, SKeown, Sprinter99 and 7 guests
