SBC Bowtie phase 2 head question.
Postby JODY » Tue Dec 01, 2009 10:25 pm
I purchased a Camaro with these heads on a 377. I'm about to have the engine freshened up and to see what all is inside.
I was wondering what kind of flow numbers some of you guys have been getting them to pull. I do know the heads were port and polished by Larry Meaux some time back but there is no identifying marks other than his name. The heads are ported out to a 1206 gasket.
Just trying NOT to spend the money to have them flowed.
JODY
Postby maxracesoftware » Wed Dec 02, 2009 3:55 am
do you know the original owner's name
because i will have the Flow Sheets..but i need to know who it was .
caution-> i've had 1 pair of Heads
that someone forged my name on the ends
come thru my shop
is this aluminum Bowtie head ?? or cast iron ?
How fast was the Car running ??
Any Pics of the Car ?
Meaux Racing Heads
MaxRace Software
http://maxracesoftware.com/bulletinboard/index.php
maxracesoftware
Postby JODY » Wed Dec 02, 2009 11:17 am
Larry,
Thanks for looking and responding.
The heads are cast iron.
I bought the car from Chad Noel. Charlie Stelly from around the Arneauxville area built the engine sometime last year he said. When I asked him about the heads all he could tell me was that he got them from a Keith or Kevin Broussard. I did find a 9 stamped on the end of 1 of the heads. The heads and intake have your name ground on to them. I wish those guys could give more information about them.
Would it help if I took a few pictures of them?
Right now the car with me in it weighs 3107lbs. I have ran a best of 10.77 @ 126 so far. Still trying to get shift points and launch rpm figured out.
JODY
Postby maxracesoftware » Wed Dec 02, 2009 4:32 pm
JODY wrote:Larry,
i found some of the History->
i originally Ported them for Scott Segura's Dragster
then Keith Broussard bought that Engine w/those Heads
put it in his 1st Dragster
then Keith sold that engine to Gene Courville
then Gene Courville sold it to Charlie
Charlie sold it to Chad Noel
Charlie told me he ran 10.50's w/ stock 1050 Dominator
i'll try to find those Flow Numbers now i know who they were for
originally but its been 15 to 20 years ago ?
knowing Scott..they were just warmed over Bowl Ported mainly
not really Ported
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 4:40 pm
JODY wrote:Larry,
this is the same Engine in Keith's 1st Dragster
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby JODY » Wed Dec 02, 2009 4:46 pm
Larry,
YOUR THE MAN!!! Thanks a ton!
Yes, Chad told me they had the car running 10.50s with a 1050 on it... right now I have a 950 HP that we just started tuning on before the winter break. It has a little too much thrust bearing walk for my taste and they couldn't remember the exact cam specs. So I'll get bearings and rings put in and some new valve springs after I find out what cam I have.
Plan on putting a small plate kit on it and have as much fun as possible.
Thanks again for looking into these heads!
JODY
Postby maxracesoftware » Wed Dec 02, 2009 5:19 pm
JODY wrote:Larry,
your Heads are probably around 265 CFM ??
i'll keep looking ... i remember seeing Scott's Flow Sheet
by accident going thru other searching for another Flow Sheet
on a 292 Turbo Head
__________________________________________________
here are a few Flow Numbers on the #034's
4.000" Bore Fixture
Stock out of box 034 Cast-Iron Bowtie heads
with factory valve job and 2.020/1.600
Tested on SF-600 FlowBench
Flow tested at 28" on 4.000" Bore Fixture
Lift----Intake----Exhaust
.200----117.9----107.9
.300----169.5----123.8
.400----205.0----146.2
.500----216.6----146.6
.550----228.3---------
.600----222.1----148.8
.650----215.8---------
.700----216.8----148.8
.750----217.8---------
***with pipe on exhaust ports
4.000" Bore Fixture
Cast-Iron Chevy Bowtie heads #034 castings
with 2.085/1.580 valves
Flow tested on SF-600 FlowBench
.200----127.7-----104.6
.300----189.2-----158.8
.400----238.5-----204.0
.450----256.6----------
.500----271.0-----216.0
.550----281.5----------
.600----288.6-----218.6
.650----293.3----------
.700----298.4-----221.1
.750----304.3
.800----308.3
.850----311.4
all out porting but no epoxy or welding
4.125" Bore Fixture
they can be made to Flow these following Numbers
SF-600 Bench 4.125" Bore Fixture
2.085/1.585" tulip titanium (all-out Porting, but no welding )
Lift__Intake__Exhaust_(No-Pipe)
.200__138.0___106.7
.300__199.1___150.3
.400__245.6___200.6
.450__263.1
.500__278.7___216.6
.550__289.7
.600__296.1___222.0
.650__302.0
.700__307.5___224.1
.750__311.4
.800__315.8___224.5
.850__319.3
.900__322.5___225.2
.950__324.0
these last Flow Numbers made 720 Peak HP on my Dyno on a
360cid Engine...it was being limited by Choke at pushrod area
from memory it was making Peak HP @ 8500 or 8600
going into a front engine Dragster
these are maxed out with HeadBolt Tubes and Tricks
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 5:42 pm
Pictures of #034 1st design
has thinner chamber walls , and flat outside, no bulging like
the 2nd design upwards, that bulged out the casting
to get the chamber walls thicker and keep water jacket circulation
Compare to 2nd design and newer versions
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 5:46 pm
the Final 5th version ??
the 4th and 5th had scalloped int flange where heat riser would be
1st and 2nd design int flange ( maybe also 3rd design ? )
Last edited by maxracesoftware on Wed Dec 02, 2009 6:07 pm, edited 1 time in total.
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 5:47 pm
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 5:56 pm
Sectioned 1st design #034 Bowtie to see
how much Porting capacity there was
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 6:00 pm
i'm getting ready to Unshroud the Chamber around the Intake Valve
from 4.030 Bore to be used on 4.125 Bore
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby maxracesoftware » Wed Dec 02, 2009 6:04 pm
unwelded pushrod area
Meaux Racing Heads
MaxRace Software
maxracesoftware
Postby Brian B » Wed Dec 02, 2009 6:10 pm
Larry
Your first couple of pic. were them consider
Phase I heads?
Brian B
Dakota Parts Warehouse
The Ferrea Valve Guy
Now stocking Hylomar
877 235 2832
Brian B
Postby maxracesoftware » Wed Dec 02, 2009 6:17 pm
Brian B wrote:Larry
Phase I heads?
Brian B
877 235 2832
i guess you could consider them Phase 1
here's 2 more Pics that i took at Brodix Foundry while visiting,
JV Brotherton told me not to show or tell anyone,
( but its been a long time ago ! )
i happened to see them on a counter, so i quickly snapped
a few Pics....but he said keep that to yourself,
you weren't supposed to see that !!
then he quickly put the head away in a drawer ! :)
Last edited by maxracesoftware on Wed Dec 02, 2009 6:38 pm, edited 1 time in total.
Meaux Racing Heads
MaxRace Software
maxracesoftware
Next
Return to Engine Tech
Who is online
Users browsing this forum: Bing [Bot], Cogburn, dbusch, lorax, Matt Gruber, mxzman, Nefario, SKeown, stokerboats, wil8115 and 19 guests
