You could even use an existing straight 6 head.
GM makes a 4v 4.2 I6 that makes 291HP- so even if you left it stock you'd make 600hp.
8.4 liters is small!!!!!!!
And you're worried about the engine being too physically big!!
SchmidtMotorWorks wrote:And you're worried about the engine being too physically big!!
Yes, I want big block dimensions and in a 60 degree V the engine gets rather tall. So I chose a pushrod design partly becuase it has better power density than a DOHC engine.
I have a design for a compact SOHC design but again the cost of developing the cams and rockers will be very high since they act directly on the rocker arms.
I have to disagree about the power density of pushrod designs being greater. Pound for pound a DOHC design will make more power.
..But doing a DOHC 4V motor would be a recreation of what every manufacturer is doing. What would really be the point?
If nothing else, validate the concerns of all those around you who, in the past, questioned your stability.
Give'em, something to talk about!
Users browsing this forum: 540 Vette, gmc406, mustangmike68, racerx1622, Sprinter99 and 7 guests
