eraser44 wrote:Joe,
34cc chamber, .060 total deck & gasket, 1 cc net dome, 4.06 bore, 3.400 stroke = 16.73 static comp by my calc's. 6.220 rod, intake closes 68 ABDC = 10.90 dynamic.
I'm thinking maybe I'm a little high, just looking for input. On freshen up I can cut the dome and lower some.
I'm not saying you are too high. I don't know. But if you haven't run the motor with lower compression, you may try it. What do other guys run?
.060 sounds like a lot of clearance between the piston and head. What is the valve angle? If it is very shallow can you move the top ring up? Reducing that volume gives you a little less area for heat to transfer and exhaust to hang out. With 17:1 I would want as little exhaust left as possible.
As far as the "dynamic compression" goes, I see how people are calculating that, but it isn't, by any means, giving you an indication of peak cylinder pressure, or rate of pressure rise after IVC for that matter. The only way to figure out "dynamic" factors is by running the engine.
If you are not increasing PVD area more with the higher spike than you lose from pumping, lowering compression will help unless the higher residual gas fraction from the lower compression hurts the combustion (in theory). The higher you get with compression, the more minimal the increase becomes. Several engineers (not engine builders though) say that 17:1 is the breakover point. But as Darin pointed out, an engine with killer heads and carburetion will have that point lower.
Winston Cup plate engines used to run extreme compression ratios before they had a rule because it helped with limited induction. You have to figure out the balance point where power starts dropping because the pumping outweighs the increase. I don't know anything about those heads, but I would guess keeping it pretty high will help.
