by SchmidtMotorWorks » Mon Nov 07, 2005 10:48 pm
Wow, thanks for all the quick input, I'll try to catch up.
RE: Flow, from what I have read the difference in flow between an radiused runner to plenum verses a horn is not noticable. I would like some informed input on that though.
RE: CAD App, I use Unigraphics NX. I work there an do this motorsports stuff to empty my bank account.
RE: Flange, that would be tough, bit it might be possible, I'll work on it. The problem is in how the casting will be made. The way I have it now I can cast if with automatic equipment in green sand, adding the flanges would probably make it an air-set sand job and double the cost of the castings.
RE: O-ring I think that I might be able to put an oring in a cbore rather than in a groove so that when you tighten the plenum it would squeeze the oring on the tubes to hold them in.
RE: Application, I tried to make it as universal as possible. I guess any BBC with conventional rectangular port heads.
RE: Porting stock, currently I have it designed for 0.200" wall thickness so that it will be light, what thickness would be preffered?
