Hello Gents
I know this is an Old tread, but I believe Its a good place to ask, I'd like to know If is possible to use a regular SBC intake bolted with angled plates with these Heads, like a Victor Ram.
sbc 18 degree trick flow heads
- BrazilianZ28Camaro
Re: sbc 18 degree trick flow heads
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
NEW BEST ET
Intake flange should be standard angle. The good 18 degree heads have raised ports.
I believe by the flow numbers and Dyno results posted here, the Heads in question are the Trickflow ultra 18s, raised runners. Am I missing something?
NEW BEST ET
NEW BEST ET
They also have a different intake flange angle, that is why Im asking...
NEW BEST ET
NEW BEST ET
No, I missed the first page, thought it was a fresh post, used to look after a raised runner 18 degree motor, I'd assumed the intake flange was correct to block because the pushrods were still too dam close to the rocker cover rail.BrazilianZ28Camaro wrote: ↑Sun Feb 04, 2024 7:11 pmI believe by the flow numbers and Dyno results posted here, the Heads in question are the Trickflow ultra 18s, raised runners. Am I missing something?
