Dart vs Brodix vs AFR cylinder heads
movealong
Post by movealong » Sun Nov 16, 2008 8:05 pm
We have a new 377 for our 2200 lb Vega, need an off the shelf cylinder head, running comp cams roller 260/268 .660 cam that he already has.
Wants either Dart Pro 1 plat 215 or Brodix Jesse James 210 cnc ported or afr competio eliminator 210 cylinder heads. All are about the same price so which one? We want the one to get us down the track fastest. any experience with these heads? thank you
af2
Re: Dart vs Brodix vs AFR cylinder heads
Post by af2 » Sun Nov 16, 2008 8:40 pm
movealong wrote:We have a new 377 for our 2200 lb Vega, need an off the shelf cylinder head, running comp cams roller 260/268 .660 cam that he already has.
Look at the chamber's and make the decision!
Then look at RHS.
Flow #'s is only what it is. :D
GURU is only a name.
revolutionary
Post by revolutionary » Sun Nov 16, 2008 8:47 pm
The AFR should be a good 20-30 better than the other two.
Daryl
Revolutionary Performance and Machine
movealong
Post by movealong » Sun Nov 16, 2008 9:30 pm
Then look at RHS.
Where can i find info on rhs ? thanks
movealong
Post by movealong » Sun Nov 16, 2008 9:31 pm
revolutionary wrote:The AFR should be a good 20-30 better than the other two.
serious? have u seen this? thanks
airflowdevelop
Post by airflowdevelop » Sun Nov 16, 2008 9:54 pm
T4P Dart 200's will make the others look like double humps. Best conventional small port head off the shelf that I have had on my bench.
Contact sstrokerace for dealer list.
movealong
Post by movealong » Sun Nov 16, 2008 10:52 pm
airflowdevelop wrote:T4P Dart 200's will make the others look like double humps. Best conventional small port head off the shelf that I have had on my bench.
what is a "T4p Dart 200"?, will they make more power than the 215 platinum? what did they flow on your bench? thanks
jmarkaudio
Post by jmarkaudio » Sun Nov 16, 2008 11:00 pm
Isn't that an LS head?
Mark Whitener
____
airflowdevelop
Post by airflowdevelop » Sun Nov 16, 2008 11:02 pm
No, Standard 23 SBC.
SStrokerAce
Post by SStrokerAce » Mon Nov 17, 2008 1:19 am
Yeah it's a pretty killer piece... there are both LS and 23° heads. They are heads Joe developed before he passed and they are very nice. His goal was to make the best possible standard port 23°
Not cheap due to some tricks with the valves (94g Stainless non-hollow valves)... but for a under 400cube SBC or LT they are hard to beat. One set is running 125mph at DA's of 6000 ft! in a 3400lbs F-body! Not bad considering it's a T56, PUMP FUEL and has a stock ECU which limits the RPM to 7000. His cam is around the same size as yours as well. You would want to run a nicely ported single plane to go along with them!!!!
Should be able to move a 2200lbs Vega into the low 150's easy.
No clue what kind of wind they move on Dennis' bench. I know they are VERY touchy to a point in terms of VJ and valve and with a 50° seat they moved over 330cfm up here on a calibrated 1020. I think we figured out AFD's bench calibrated to his normal orifice is a percent or so lower.
[img]http://photos-g.ak.fbcdn.net/hphotos-ak-snc1/hs139.snc1/5928_111214857139_110806152139_2127222_6826389_n.jpg[/img]
[i]Those of you who think you know it all are particularly annoying to those of us who do[/i]- Penske garage sign @ Indy circa '71
movealong
Post by movealong » Mon Nov 17, 2008 1:45 am
Im interested. anybody know how much they are? does dart sell them? thanks
Tokyo Torquer
Post by Tokyo Torquer » Mon Nov 17, 2008 7:46 am
I would like to hear more about these T4P heads.. found the Bauer racing website, but it has nothing on it about these heads... actually the whole site is nearly empty aside for some info about throttle bodies. The LS guys were saying that Bret Bauer buys the heads from Dart, sends them out to their porter of choice and then sells them on the boards.
1973 RS Z28: 401ci Dart Little M, Littlefield 8-71 supercharger @14lbs boost, Callies Magnum crank, Lunati rods, JE pistons, 7.8:1, AFR 227 Comp heads, T&D 1.6 shaft rockers. Reed solid FT cam (240/250@.050-.523/.542 lift-112 LSA), QFT 750 carbs
SStrokerAce
Post by SStrokerAce » Mon Nov 17, 2008 11:37 am
movealong wrote:Im interested. anybody know how much they are? does dart sell them? thanks
They are Dart castings but Dart does not sell, them. We are a Dart dealer.
Cost is more than anything else on your list here... it varies with the application and spring setup. Unless you want to spend money you probably don't want them, they are NOT cheap.
If you need more info shoot me a e-mail.
Bret
movealong
Post by movealong » Mon Nov 17, 2008 11:51 am
Well if they are too much money, then which cylinder head on the list. we can definitely afford those. thanks
Rommel Racing
Post by Rommel Racing » Mon Nov 17, 2008 12:40 pm
What is the reason for this?
Steve :)
-3400lb stock suspension 67 Camaro
-10.5-1 compression pump gas 540bbc.
-th-400, 4200 stall 9" convertor
-12 bolt 4.10's
-29.5x10.5 Hoosier radial slicks
- Best on motor only 9.59/142.24mph
