And the exhaust duration is 23-30 degrees longer then the intake.Big Speed wrote:Current technology Pro-Stocks are 55-60%.so are many other high HP per cu.in.racing engines.find the right balance of air flow,port size,crosssection,air speed and cam timing its a balancing act ,many hours of R&D
Pro Stock is as advanced as it is because of the influx of NASCAR cam and port design technology.
The Exhaust flow is very important in cam design, and any top cam designer will tell you this.
When you start working on top class racing like Pro Stock, Indy Car, and NASCAR, where you have a lot more restrictive rules, and the engines need to be extremely efficient, you really see where tuning the exhaust comes into effect. It's something that escapes the "throw a bigger cam in it" mentality of most drag race engine builders.
