rmbuilder wrote:In the conventional firing order 5 and 7 pull fuel to the back of the engine and then 2 pulls to the front at the opposite end. This became a problem in BBC because the number 2 and 7 cylinder ports are long. 5 helps 7 pull to the back then 2 tries to pull forward and gets lean. You do not see this on 1 and 8 because they are short runners. By revising order (swap 7 and 4), 8 helps 7 and 4 helps 2. Thus, your fuel distribution is more balanced between cylinders.
learner wrote:there is no firing order that will not leave at least one pair firing next to each other
learner wrote:The only thing i can see is if the 4/7 swap is designed to help distribution under acceleration a static dyno won't tell you anything.
SW wrote:Here's a firing order that puts the pulses 90* apart, you should hear it run.
1,5,7,3,6,8,4,2
shawn
Users browsing this forum: Baprace, Blacktrack, GregGood, racerx1622, SKeown, Sprinter99 and 5 guests
