Joe Mendelis wrote:I have seen manifolds pick up airflow before as well as hurt it. I flowed a BBC Victor head that flowed 390 and with the manifold flowed 408. LT1 stock head with valve job flowed 235 and backed up at .440 lift. With the manifold attached it flowed 215 from .400 up and never backed up. The worst one I've ever seen was a GT40 Ford. It took a 1.94 valve port flowing 280 and knocked it down to 206!! One thing to mention about very long runner manifolds is that they will hurt flow as well as murdering your torque at higher piston speeds. An SB2 manifold for the most powerful Chevy Cup engines lose 20 CFM with carb attached as well.
bill jones wrote:-We did some MPH tests on a 393ci SBC in a rear engine dragster years ago and all we did was port the single four manifolds.
-We started with a set of heads that I adjusted the flow on each head port to 268CFM (at 25") using a radius inlet, then installed the intake and the carburetor and the air pan for the scoop.
-First manifold was a Victor JR with a $150 fluff & buff that averaged 246.75cfm and the car ran 159.6MPH.
-then I spent all summer and ported on several different manifolds and for each "average" CFM gain that I got averaged of the 8 runners, the car went one mph faster.
-When we got done we had improved the various manifold runners up to an average of 257.25CFM and the car was then running just under 170mph.
-The only other thing we did was to jet the same carburetor around to suit what we thought we were seeing with the sparkplugs as we found the porting changes also changed where the fuel needed to be within the engine.
Users browsing this forum: Baprace, Blacktrack, gmc406, Google [Bot], IDEALER, racerx1622, SKeown, Sprinter99 and 5 guests
