How do you finish primary tubes inside a collector?
Getting ready to build my second set of headers in a couple weeks and wanted to ask you guys how you should finish weld the primary tubes inside the collector. I have dimensions from Pipemax -- 1-7/8 primary tube 30.4-33.3" long with a 3.5" x 8.5" (or 17") collector.
What kind of angle should the tubes join at? Should the exit be at a flat 90* angle or tapered and smoothed (like below)? Anything to be gained (or lost) by doing this correctly?
Here is how I did my last set (my first attempt).
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro 427" E85 powered small block, 9.95 @ 133 mph best motor ET through the mufflers. 1.319 best sixty foot.
Transition from primary to collector is an area where gains can definitely be made. The goal is to reduce turbulence and create the smallest collector area possible that results in the desired outlet diameter. This is what merge collectors are designed to do. The picture you show is in the right direction. Examine the designs at burnsstainless.com or any site with good internal pictures of merge collectors to get more ideas.
Nice looking work! I like what you did on that first set. From what I can gather each application is different. From what I can gather, and please correct me if I am wrong, merge collectors and a set up like the Pro Stock headers are good for a higher RPM with a narrow RPM band. If you were doing street headers then that is a whole different ball game.
John
John
one of these days I will have my web site done ;-)
Thanks guys. I like the idea of pre-bent collectors and will definitely shop around to see what there is. Not sure what is out there that doesn't cost an arm and a leg in 304.
I am building this next set out of 304 stainless and I expect that grinding will be more work than the mild steel set I did before. Just want to make sure that what "looks nice" actually performs. LOL
FYI. The application is a bracket car that may make a trip on Drag Week and an occasional heads up or indexed type event. Running a full 3" exhaust with X pipe if that matters.
You might want to take a look a www.coneeng.com for header parts. They may have what you need at a "reasonable" cost. I'm using their parts to build my set of headers. I envision by headers to look like your first example.
Update: Cone sells the center spikes, bullets or what ever you want to call them. I just had mine welded up and they came out real nice.
Edelbrock sells nice looking merge collectors for only $99/PAIR through Summit! Available in various sizes. Below is 1-3/4" x 3"
http://store.summitracing.com/partdetai ... toview=sku
Follow the link below to the Edelbrock site for more information, and to see what all sizes are available. Call Summit or Jegs with the part number to get the price for that size.
http://www.edelbrock.com/automotive_new ... tors.shtml
Good Luck!
Good Luck!
i got mine from cone to
here are a pic still have one headers to build ...
http://www.forum.shraboras.se/download/file.php?id=8
Good stuff guys. Thanks for the links.
I noticed on the cone eng site there are different angles for the primary pipes coming into the merge. How do you know which angle to go with?
I had to come take a look since we were getting so many web hits from here! Great site! I think you'll like this new way of building merge collectors and the prices as well.1989TransAm wrote:You might want to take a look a www.coneeng.com for header parts. They may have what you need at a "reasonable" cost. I'm using their parts to build my set of headers. I envision by headers to look like your first example.
Eric- Each tube diameter has a taper specific engineered collector and merge bullet. Users can also tweak on them a little bit to further tune them based on their particular needs. Your primary tube coming into the collector can also be angled unlike a welded merge to save lots of space.
Since they are welded in place (you can make them into a slip fit also if so desired) you get much better sealing than with a traditional welded merge collector. You can also easily polish the bullets after they are welded in place and before collector is welded on, unlike a welded merge that you have to try and reach inside the collector from the little outlet opening to work. Complete build instruction with pics here: http://www.coneeng.com/weld_on_collector_kit.html that whole kit shown retails for $115 in MS and $150 in SS.
Check out the dyno results on the home page to compare a high-end welded merge to a Megs Merge.
