Hey guys
Can someone give me a formula to calculate actual curtain area at different lifts, taking into account seat angle & width ?
Thanks.
shawn wrote:Greg,
check your emails.
shawn
ChrisU wrote:HHmmmm I'm looking for something that will account for the dynamic area created by the entire valve event.... To me it doesn't matter about the angles and such as I'm looking to have relative information based on different cam events and rocker ratios and such....
ozrace wrote:... but it calcs curtain area using valve circumference x lift.
I was hoping someone has a way of calculating the actual area available with a 45 degree seat. i.e. at .100" valve lift you get a lot less than .100" of opening at the seat.
bill jones wrote:-What I did was pretty simple.
-I used my flowbench valve opening tool ands open the valve in .100" increments and then used a pair of dial calipers or a set of pin gages to measure the actual opening and multiplied that by whatever circumference it is that you feel is represents the curtain.
-I double checked this several times and this is what I got, even tho it doesn't add up right and it wouldn't be what you would calculate if you were an engineeer, it is what I actually measured.
Users browsing this forum: Sprinter99 and 11 guests
