AM I JUST FULL OF HOT AIR???
I have a SBC-400,Blown and nitrous too,but this without nitrous....I got many runs on my 3575# malibu with it at 21# of boost(no nitrous) and it goes 60ft/1/8m/1/4m...1.48/6.10,117/9.48,147.....I put a big bottom pulley to redline the YSI blower and have 26#and it goes 1.38/5.68,123.76/8.99,147........5 mph more in the 1/8,and the same 147 in a 1/4....Plugs look good....I think it's hot air(No cooler) just bought a water/alcohol injector......ANY BODY ELSE HERE HAD THIS PROBLEM????? OLDHEAD
Quicker then most
Re: AM I JUST FULL OF HOT AIR???
oldhead wrote:I have a SBC-400,Blown and nitrous too,but this without nitrous....I got many runs on my 3575# malibu with it at 21# of boost(no nitrous) and it goes 60ft/1/8m/1/4m...1.48/6.10,117/9.48,147.....I put a big bottom pulley to redline the YSI blower and have 26#and it goes 1.38/5.68,123.76/8.99,147........5 mph more in the 1/8,and the same 147 in a 1/4....Plugs look good....I think it's hot air(No cooler) just bought a water/alcohol injector......ANY BODY ELSE HERE HAD THIS PROBLEM????? OLDHEAD
Well you are going quicker because you have boost sooner.
When boost goes up and power does not, it's a sign of restriction.
After-cooling can help. I'm unsure how much that type of cooling will help your situation (because you are putting more fluid into the intake)
Is this carbureted? The methanol/water injector will still help some if it is, but it may not be the end all to beat all.
I put one on a FI/Vortech T-Trim SBF and it picked up over 80 HP with no changes to fuel & spark. A lot was left on the table but the customer is sort of a maniac behind the wheel so I wanted to make sure there was some in the bank.
I WANT TO THANK YOU FOR YOUR REPLIES......Yes it is a blowthru carb'ed engine.You will note that power went way up in 1/8 mile,5 MPH.The car felt like when I spray it with a 150 shot.....I just bought a Innovate data logger,but not using yet.....Cog belt....Local dyno owner said he saw 175 hp. on a blown BBC. using pump gas......150 on another....usind a Snow W/A injector....THANKS..Oldhead
Quicker then most
Are your valve springs up to snuff. If there weak and start floating some they will limit the RPM of the engine....like a rev limiter. Just something else to check.
Blessings.......Ron.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
John 14:6
Ron Clevenger
THANKS AGAIN: Went back to 21# and sprayed it with a 150HP....Went 1.35,5.40 at 129.21,8.80 at 152.75....Forgot to leave tires down from 12 to 10....You know what I still have the 3:50 rear in.... OLDHEAD
Quicker then most
RPM?
you don't say what RPM, or duration of your camshaft?
thinking what black z is thinking, maybe too much gear?? wonder if something in the low 3.xx's would help?
Sorry wrong info.....I just went 1.35/5.60 at 123.93/8.80 at 152.49....Got time slips mixed....Cam is 248-260 roller at 114cl. Never take it over 7000.....I like the street convertor that I have its a 2400 rpm,10 1/2",about 38 deg.postive angle,with a 2.3 multplying stator.....But slips 19%......OLDHEAD....Hope to try w/a injector soon....OLDHEAD
Quicker then most
WOW 19% with only 2.3 STR? Who built this converter? Abe Lincoln! The newest converters are seeing 2.5-2.6 STR and obtaining 92-93% effeciency on the big end.
@ 26PSI your air temp is over 280 degrees not withstanding frictional heat!
1. Get a new converter
2. Intercooler
3. then spray some dope to it
4. Did I mention the converter or intercooler yet?
2. Intercooler
