aftermarket main caps-383
At what point should you consider using aftermarket main caps for a 550-600 h.p. 383 sbc?
Re: aftermarket main caps-383
Look in the GM catalog and see what they rate a stock cap block at!!!brket racer wrote:At what point should you consider using aftermarket main caps for a 550-600 h.p. 383 sbc?
Here are some links to look over
http://www.chevelles.com/forums/showthread.php?t=38173
http://www.nastyz28.com/forum/showthrea ... post264731
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
