Fresh 358ci SB2.2
Phantom Race Engine # PRE363
GM 1184 bowtie SB2.2 block - 4.185 bore
Bryant 3.260 stroke 8 counterweight billet crank
Carrillo 6" H-beam 1.850 journal rods
JE FSR pistons
Gibbs oval port SB2.2 heads
Wilson ported GM 854 intake
7mm x 2.180 x 50* titanium intake valves
5/16 x 1.600 x 55* titanium exhaust valves
PSI 1242 valve springs - 2.030" installed
Titanium retainers
Jesel 1.75 - 1.70 shaft rockers
Jesel .875 tiebar roller lifters
Billet aluminum valve covers
Comp Cam 55mm billet roller cam
Jesel belt drive on cam
Stainless steel drysump oilpan w/piston squirters
Stewart waterpump
Auto Verdi 6 stage drysump oilpump
Brown & Miller oil lines
MSD distributor
Delphi sparkplug wires
Bosch F2CS sparkplugs
Valve lash .016 hot
Timing 32*
809hp @ 7500 rpm
592# torque @ 6400 rpm
Engine has new crank,rods,pistons,cam,lifters,valve springs
$17,500.00 cash
Pictures & dyno sheet available by email.Also have a video of one dyno pull.
EMAIL: terry.marciaburnett@gmail.com
PHONE: 865-567-6943
FRESH 358ci SB2.2 - 809hp
