Good it was something so simple ... but if one cylinder was misplaced, another one also had to be out of sequence ... ?? ... or is the firing order 18636572 ..?Belgian1979 wrote: ↑Tue Dec 26, 2023 2:05 pm Found it!
Stupid thing that I probably did. In the EGO program the number 6 referred to the number 4 cylinder, which is why it kept on trying to correct fuel downward, but wasn't able to get anything done. So this fixed it.
Hopefully others will learn something from my stupid mistake.
One cyl to rich at idle
Re: One cyl to rich at idle
No there were 2 cyls (4 and 6) that were referring to the O2 of number 4...So 4 ran correctly, 6 did not.Tuner wrote: ↑Tue Dec 26, 2023 2:37 pmGood it was something so simple ... but if one cylinder was misplaced, another one also had to be out of sequence ... ?? ... or is the firing order 18636572 ..?Belgian1979 wrote: ↑Tue Dec 26, 2023 2:05 pm Found it!
?? I think I understand ?? 8 cylinders, 8 sensors, the incorrect sensor number was assigned to one cylinder?Belgian1979 wrote: ↑Tue Dec 26, 2023 3:29 pmNo there were 2 cyls (4 and 6) that were referring to the O2 of number 4...So 4 ran correctly, 6 did not.Tuner wrote: ↑Tue Dec 26, 2023 2:37 pmGood it was something so simple ... but if one cylinder was misplaced, another one also had to be out of sequence ... ?? ... or is the firing order 18636572 ..?Belgian1979 wrote: ↑Tue Dec 26, 2023 2:05 pm Found it!
