PSI valve springs
winterhoff
PSI valve springs
Post by winterhoff »
Anybody have a good source for PSI springs JHE- 10A and JHE-002 retainers
Thanks Ron
Newold1
Re: PSI valve springs
Post by Newold1 »
Summit actually stocks and sells some of the PSI spring sets.
As for your area, give PSI a call and they will direct you to a few sellers in your area.
Abbottracingheads
Post by Abbottracingheads »
CV Products or Motorsports Unlimited.
ou812
Post by ou812 »
Isky sells them, and I believe Chad Speier sells them also.
Brian Hafliger
IMM Engine & Dyno
http://www.immengines.com
http://www.neilhepburn.com
Alaskaracer
Post by Alaskaracer »
Call PSI directly. They are great to deal with and will put you in contact with a retailer they recommend. I did and they even gave me a discounted price. Nice folks.
Mark Goulette
Authorized Amsoil Retailer
cpmotors
Post by cpmotors »
Abbottracingheads wrote: Fri Dec 07, 2018 11:05 am CV Products or Motorsports Unlimited.
X2 On Ken @ MSU. 216-390-4561
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Cylinder Head Fixture for Vertical / Surfacing Mills since 2008
Charliesauto
Post by Charliesauto »
winterhoff wrote: Thu Dec 06, 2018 6:40 pm Anybody have a good source for PSI springs JHE- 10A and JHE-002 retainers
Thanks Ron
Those JHE PN's are only available from Hornick, the springs are exclusive designs made for JHE by PSI.
I believe you will have to buy the springs from Joe. May be able to source a compatible retainer through DW or Xceldyne.
If you go to his website, find the valve spring spec page and scroll to the bottom for the JHE #'s.
JHE contact (704)664-7322 jheinc.com
LSP
Post by LSP »
Charliesauto wrote: Sun Dec 09, 2018 5:19 pm
Thanks Ron
Correct, ask for Rick @ JHE Inc.
