Solid vrs roller cam on a street motor
crazycuda
Post by crazycuda »
Im not trying to start a debate on which is better but I am trying to understand a little better when it comes to parts wearout.
I have noticed on most solid roller cams (BBC and ford) alot of locals are changing out the lifters on a yearly basis because the roller pinions are wearing out. Yet the hyd rollers last many miles. I know lift and valve spring pressures play a big part, but is a solid roller on the street really worth the extra power over a reg solid lifter cam? (pending the cam and motor are matched) I understand the quality of the roller lifter plays a part on its longevity. In all reality though how many co's make solid roller lifters?
Sorry if I ask alot of questions, but you never stop learning if you ask questions
blykins
Post by blykins »
There will be differing opinions, but I would use a solid roller for a weekend toy and no more. Like you mentioned, people are having to change the lifters yearly. The introduction of pressure fed lifters has increased the lifter life here in the past few years but it is still recommended that they be checked once a year or so.
Comp Cams has their Endure-X line of pressure fed lifters. I think Isky and Crower make some high quality solid roller lifters as well.
I think the reason that hydraulic rollers last so long is that they are not continually hammered against the cam like a solid roller lifter is.
If I were forced to use a solid cam, I would choose a roller cam just for ease of break-in. I've also heard the friction loss is good for some extra ponies as well.
F1Fever
Post by F1Fever »
I agree. I also wonder why somebody hasn't make a tight lash (and I mean tight!, like .006") solid roller for the street?
I was no longer driving the car consciously. I was driving it by a kind of instinct, only I was in a different dimension.
West Siloam Dispensary
Tod74
Post by Tod74 »
F1Fever wrote:I agree. I also wonder why somebody hasn't make a tight lash (and I mean tight!, like .006") solid roller for the street?
I had a lifter fail in a BBC and broke the block. It was a comp cams roller and the recomended lash was .028 and .030 so that is what I ran..I thought that was too loose but figured the cam company knows more than me ..well now I am paranoid .My new engine has a Crane grind and the cam card said .026 and .028..but to be safe I set them at .017. My question is...will this hurt anything? I used to think that the recomended lash was just whatever made the best power on the dyno...but since reading this board the last few months,I gather from the posts here,that the lobes on the cam are designed for a certain lash....that it isn't just a tuning thing.So, what effect(other than making the engine think it has more cam) will running a considerable amount less lash than recomended have?
blykins
Post by blykins »
I don't necessarily think that the lifter failure was due to your lash setting. What part on the lifter broke? The body or the bearing end?
CamKing
Post by CamKing »
Tod74 wrote: I had a lifter fail in a BBC and broke the block. It was a comp cams roller and the recomended lash was .028 and .030 so that is what I ran..I thought that was too loose but figured the cam company knows more than me ..well now I am paranoid .My new engine has a Crane grind and the cam card said .026 and .028..but to be safe I set them at .017. My question is...will this hurt anything? I used to think that the recomended lash was just whatever made the best power on the dyno...but since reading this board the last few months,I gather from the posts here,that the lobes on the cam are designed for a certain lash....that it isn't just a tuning thing.So, what effect(other than making the engine think it has more cam) will running a considerable amount less lash than recomended have?
It depends on how the clearence ramp was designed. It'll either have no effect on valvetrain stability, or it'll help. It won't hurt anything but performance.
It's not the tightness of the lash, it's the velocity of the cam at that point that dictates how hard the lifter hits the cam. You can have a cam designed for a looser lash that has less velocity at the lash point then a cam designed for a tight lash.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
CamKing
Re: Solid vrs roller cam on a street motor
Post by CamKing »
crazycuda wrote: I have noticed on most solid roller cams (BBC and ford) alot of locals are changing out the lifters on a yearly basis because the roller pinions are wearing out.
If you go to a roller lifter with pressure oiling to the needle bearings, you triple the life of the standard rollers. Morel, Crower, Isky, and I think Comp all offer this type of lifter. We sell the Morels, which can be rebuilt for 1/2 the price of new ones.
The other thing you need to think about is, if you're going to go to a high lift, aggresive flat tappet cam to try and get the power close to that of a roller, it won't last long either. 24,000 miles is a lot for an aggressive flat tappet cam.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
F1Fever
Post by F1Fever »
Camking, how hard would it be to develop a tight lash solid roller? It seems like an initial ramp similar to a hyd roller would work with only a small decrease in performance and there would be a large demand for a cam like this. Is this practical or am I overlooking something in my line of thinking?
crazycuda
Post by crazycuda »
Just adding to not arguing. Using $ as a factor the typ solid roller lifter set costs 300+ for a bbc. A solid lifter cam +lifter kit averages the same price. I think most people (on a street toy) would put 24k on a motor over a 3 year period.
CamKing
Post by CamKing »
crazycuda wrote: Using $ as a factor the typ solid roller lifter set costs 300+ for a bbc.
Good mechanical Roller lifters with pressure oiling will cost around $500.
Flat tappet is cheaper, but you won't make the same power.
It's all up to the user. Is 40 extra HP worth $400-600?
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
AdioSS
Post by AdioSS »
cstraub wrote:The pressure fed lifters like Morel, Isky, and Crower will "cushion" the needles durning low rpm idle time in a street engine. The lack of oil splash at this rpm is the killer to lifters..
How come hundred of millions of hydraulic roller lifters that never see 4000 RPM live for years and years?
Could part of the problem be that when an engine builder builds a solid roller engine, they usually cut down oil flow to the lifters?
Is it all the oil routing inside the lifters?
Cheston Phillips
96 Impala SS
05 Silverado
blykins
Post by blykins »
I'm definitely not an expert in roller lifters, but could it be that the solid roller lifters are continually hammering the cam....and that tied with decreased oil splash at low rpm kill the bearings?
The hydraulic roller lifters may not be bathed in an oil bath all the time, but they have a lot softer ride without being shocked.
Also, is some of the oil from inside the lifter routed to the bearing end? That would be fed by oil pressure through the lifter galley, right?
CamKing
Post by CamKing »
The hydraulic roller cams don't run as much spring pressure, and don't have as high of an acceleration rate.
Hydraulic rollers are starting to have problem though. In the marine industry, they're having problems with hydraulic roller lifters showing excessive wear. The problems started showing up when the oil companies started taking the zinc out of their oil. Marine engines spend a lot of time idling around with very little splash oil getting to the lifter rollers.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
pitts64
Post by pitts64 »
I'm waiting to see some high roller mileage before swapping out my old Rhoads / Ram Air 4 cam in my 455 street Pontiac.
I understand the Crower HR lifters are made by Comp cams.
Tod74
Post by Tod74 »
blykins wrote:I don't necessarily think that the lifter failure was due to your lash setting. What part on the lifter broke? The body or the bearing end?
The roller wheel was broken in several pieces and all the needle bearings ended up in the pan.The link bar was broken and the lifter had turned sideways and ruined the cam...the body where the link bar attaches was broken also. I don't know if the link bar broke first, allowing the lifters to turn sideways,thus grinding the roller until it broke...or if the roller broke first..I would think the wheel went first but no way to know.
This is what I DO know.
They only had 20 passes on them and the springs were new and matched to the cam. I think they are 240 on the seat and 675 open..can't recal.THE ENGINE NEVER FLOATED the valves.On the day it broke it was 2 tenths slower than normal and seemed to slow down every pass...but never missed out.Chalk that up to inexperience on my part..that was definitly a red flag that I missed.I was concerned about it slowing down...but it was on 4th of July weekend a few years ago and it was miserable hot...in the high nineties.I just convinced myself it was the heat that made it slow down...I think it was broken on the last pass the week before ...but who knows.I ran the valves before we went and didn't notice anything.
One thing though..I did have oil restrictors in it at the time(never again)and these were just basic 275 dollar comp cams super roller lifters. Not saying they are bad..BUT...this time I got Crane Ultra Pros that cost 514. dollars,they seam like a much beefier lifter to me.
