Peak RPM/HP
Peak RPM/HP
What determines and controls the Peak Rpm Hp Point of 4 cycle engines? By point I mean the highest arc or crossover point as seen on dyno graphs and printouts. Thanks
Re: Peak RPM/HP
Nearly every component plays some role in setting peak hp rpm in every combination.
The size and shape of the intake tract is by far the most influential factor in determining peak hp rpm.
Rick
Rick
Re: Peak RPM/HP
Choke flow causing the plateauing of air mass, assuming the engine isn’t artificially running out of fuel.
Whether that be at the valve, pushrod pinch, carburetor venturi, restrictor plate, etc.
Your lawnmower, NASCAR, jet engines, Formula One, etc all work that way.
https://en.m.wikipedia.org/wiki/Choked_flow
-Bob
Re: Peak RPM/HP
Technically speaking, peak hp is reached at the rpm point where torque begins falling off faster than rpm can increase.
Varous factors can influence it, but usually it amounts to running out of breathing for some of the reasons already mentioned above.
Re: Peak RPM/HP
Most engines won't actually have have choked flow in inlet. A restrictor engine yes but but otherwise generally not as the engine looses filling efficiency before that pointhoffman900 wrote: ↑Mon Nov 26, 2018 11:18 am Choke flow causing the plateauing of air mass, assuming the engine isn’t artificially running out of fuel.
Re: Peak RPM/HP
In a NA motor in a magical world if you had unlimited Cam, port area/ airflow and unlimited rpm potential then at point the motors internal fiction load would match the HP being made and the HP curve would then hit its peak and nose over.
Re: Peak RPM/HP
I like engines made so that both Hp and T keep going up past where they cross at 5252 rpm!
Re: Peak RPM/HP
Intake runner length, cam can rock the curve some, but not move the peak hp much.11secAvanti wrote: ↑Mon Nov 26, 2018 10:45 am What determines and controls the Peak Rpm Hp Point of 4 cycle engines? By point I mean the highest arc or crossover point as seen on dyno graphs and printouts. Thanks
Re: Peak RPM/HP
The maximum torque or power that can be developed is determined by the amount of fuel that can be burned.
The amount of fuel that can be burned is determined by the amount of air mass trapped in the engine.
Trapped air mass per stroke determines torque.
Trapped air mass per unit time determines power.
The key is "the amount of fuel that can be burned", not merely the amount of fuel sent to the engine.
Torque, at any given rpm determines power.
If torque is fixed and rpm increases so will power.
If rpm is fixed and torque is increased so will power.
If both are increasing, peak values have not been reached.
Re: Peak RPM/HP
Personally, I don't give a shit if it's 600cc or 600ci. As long as it makes good power for the application, that's all that matters to me. Ford, Honda, Pontiac, Yamaha, whatever...
And it doesn't have to be small.
So you like coyote engines? See? I can do that too.
What exactly was the purpose in saying that anyway except to start shit?
Re: Peak RPM/HP
Its actually a valid technical point. The rpm where torque and hp "stop going up" is primarily determined by the displacement (and particularly the stroke) of each cylinder.
Valid technical point #2. 5252 rpm is only a meaningless number that varies depending on the unit system you happen to be using.
I am sure pdq67 understands both of the above but there are many visitors who could mis-interpret what he said.
Re: Peak RPM/HP
Many think that,.. but that hasn't been the case in my experience.
Induction tract seems to be top of the list.
Randy
Re: Peak RPM/HP
I agree with this, take an engine with long runners let's say 20" total and shorten it to 14-15" total then peak hp rpm may increase 1000rpm
