Ported LS3 10 degree heads
Carnut1
Post by Carnut1 »
A proprietary gig so this will not be a full disclosure thread but I thought some may be interested. I also have only done one LS3 head before so this will be a learning curve. This flowsheet is after a bit of developement on stock valve job. 2.2" intake 1.6 exhaust. These start big so just hogging them out won't help. Input welcome.
CGT
Re: Ported LS3 10 degree heads
Post by CGT »
15 degree head
Carnut1
Post by Carnut1 »
I haven't measured it but I was told it is a 10 degree design. Aftermarket casting.
Carnut1
Post by Carnut1 »
Stock flows
Rowdy Yates
Post by Rowdy Yates »
Sounds like Frankenstein Ls castings there Ls heads are 10 degrees only one I know of that has that valve angle. That's on all Ls heads cathedrals, Ls3 and Ls7 also. Chris did my factory Ls3 heads stage 1 port.
https://frankensteined.net/shop/f310/
Carnut1
Post by Carnut1 »
Rowdy Yates wrote: Sat Nov 24, 2018 12:55 pm Sounds like Frankenstein Ls castings there Ls heads are 10 degrees only one I know of that has that valve angle. That's on all Ls heads cathedrals, Ls3 and Ls7 also. Chris did my factory Ls3 heads stage 1 port.
I was told it is a China casting but it seems to be pretty well done. Nice machining, no porosity that I can see, cuts nice and the guides seem to be hard when the burr nicks them ( for whatever that may be worth). I am not thrilled with the fin in the bowl but I will work on that. Thanks, Charlie
Carnut1
Post by Carnut1 »
From the pictures that looks very much like it.
Casper393W
Post by Casper393W »
You know me... I'm a Die hard Ford man...but those LS3 heads rock! Good work! I'm sure you will pick up even more as you go... It's completely different starting out with a head that is "big" to start with!
Good luck look forward to seeing more..
Andy
Carnut1
Post by Carnut1 »
Thanks, Andy. I am seeing some China quality in guide and seat placement. Not terrible but not fantastic either. Needed to load the honall with 8mm stuff to get em a bit straighter. My first venture into 50 degree seats.
Carnut1
Post by Carnut1 »
First venture into 50 degree seats. 40,50,60 blend on both seats. Very short top cut. Damn, like an idiot I forgot to face the valves! Ok, I will reface and retest. Still interesting to see with a 50 seat and 45 valves there is a slowdown on intake ssr and a pickup on high lift flows.
steve cowan
Post by steve cowan »
charlie,
interested in application for these heads if you can say
can you disclose min and avg CSA so i can paint a picture,i know nothing about LS1-LS3 etc i am still in the stone age GEN 1 so i am curious.
i see the exhaust velocities are erratic and i am assuming you are testing without a pipe?
i test with a modified pipe and readings are way more stable,i guess the air does not know which way to turn.
steve c
"Pretty don't make power"
Carnut1
Post by Carnut1 »
steve cowan wrote: Sat Nov 24, 2018 3:30 pm charlie,
These are being developed for some bigger inch higher rpm applications. No measuring of anything so far. Exhaust airspeed is Pitot gauge at exhaust flange. Also tested with a 1 7/8" pipe which is too small. I will look around the scrap bin at work for some 2" aluminum tubing
Carnut1
Post by Carnut1 »
Maybe I need to explain my exhaust airspeed layout. First airspeed in top left corner is from top left corner of port flange, etc. They are usually done about max actual lift I think the head will be used at. Thanks, Charlie
af2
Post by af2 »
Carnut1 wrote: Sat Nov 24, 2018 9:18 pm Maybe I need to explain my exhaust airspeed layout. First airspeed in top left corner is from top left corner of port flange, etc. They are usually done about max actual lift I think the head will be used at. Thanks, Charlie
Why you even consider exhaust flow is beyond me. Unless you have a kink in the bend there is no way to see the actual flow.
GURU is only a name.
steve cowan
Charlie,
i understand you say straight there will not be full disclosure at the start of the thread,not sure if its time constraint or secret squirrel stuff but is the first flow sheet a standard 45 deg seat??
second sheet out of the box head?
third sheet using 50deg seat but valve angle no good so information flawed,
Carnut1 wrote: Sat Nov 24, 2018 3:37 pm
you say you have not measured anything yet??
this is the first thing i do,where do you go to if you dont know where you are headed.I dont want to sound disrespectful and it is NOT my intention.
APPLICATION,RPM,MIN CSA,AVG CSA,COMPRESSION,THROAT % etc etc
what changes to the combustion chamber (if any) to compliment the 50deg seat for pressure recovery etc etc.
please dont be upset with me Charlie as i want to learn as much as the next person and if you can not disclose any information that is fine as well,just need to say so but with out some relativity you leave yourself open to speculation.
steve c
