YEp but they wont post it typed regular with no spaces
Fully ported intake
Re: Fully ported intake
Depends which manifold. You could do a fully ported Victor Jr. and it would make less power than an otb Super Victor 2. A dominator on a good manifold will be up compared to a unported and 850 combo, but again, depends which manifold.
OK, got it: One of the "Disappeared."
Wow I didn't know that...cjperformance wrote: ↑Thu Oct 11, 2018 8:13 pmBecause if you type it without spaces you just get an *
Eg *
If your short times are less than stellar a large carb and intake could make it worse. You could have better results working on your clutch.
Yes many stock intakes leave a lot on the table. If you were below 5500rpm it would gain next to nothing.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
918-520-3480
www.wengines.com
More hp technically should always win if gear and converter are optimized for it. But if they are NOT optimized...... then overall average power would likely win.
Fully ported by a average guy at home and the same done by a shop that does such as a specialties will show a 10 hp spread!
Whats the car run now?redliner wrote: ↑Thu Oct 11, 2018 1:34 pm (3100 lb drag car)Would a 414 sbc with 11.5-1 compression and a cam that is done at 7000 heads that are 2.5 @ pinch be quicker with a fully ported and modified plenum manifold and a Dominator or an as cast manifold and a 850 carb? Just looking for thoughts...
What is your vacuum reading at the end of the quarter? During the run? If you are above 1.0" of vacuum, you may benefit from the Dominator. I have found that a well prepared plenum will increase the airflow by 30 cfm in many intakes, without touching the runners' exits. Need to prepare the air and fuel to turn into the runners, and do so without slowing it down or turbulence.
Joe-71
CGT wrote: ↑Fri Oct 12, 2018 12:54 pmWhats the car run now?redliner wrote: ↑Thu Oct 11, 2018 1:34 pm (3100 lb drag car)Would a 414 sbc with 11.5-1 compression and a cam that is done at 7000 heads that are 2.5 @ pinch be quicker with a fully ported and modified plenum manifold and a Dominator or an as cast manifold and a 850 carb? Just looking for thoughts...
Best so far is 1.447, 4.150,6.448,106.44 8.446,10.148,131.69 in the Midwest, Cordova Dragway, 3100 lbs, Liberty TKO 600
I do nt know vac. readings but am running a Mark Whitener 1050 Dominator on S p e i e r modified Motown intake.Joe-71 wrote: ↑Fri Oct 12, 2018 1:06 pm What is your vacuum reading at the end of the quarter? During the run? If you are above 1.0" of vacuum, you may benefit from the Dominator. I have found that a well prepared plenum will increase the airflow by 30 cfm in many intakes, without touching the runners' exits. Need to prepare the air and fuel to turn into the runners, and do so without slowing it down or turbulence.
redliner wrote: ↑Fri Oct 12, 2018 1:10 pmI will be at Cordova this weekend. Hopefully they prep the track well.CGT wrote: ↑Fri Oct 12, 2018 12:54 pmWhats the car run now?redliner wrote: ↑Thu Oct 11, 2018 1:34 pm (3100 lb drag car)Would a 414 sbc with 11.5-1 compression and a cam that is done at 7000 heads that are 2.5 @ pinch be quicker with a fully ported and modified plenum manifold and a Dominator or an as cast manifold and a 850 carb? Just looking for thoughts...
Frankshaft wrote: ↑Fri Oct 12, 2018 2:20 pmI am out for the year having busted my trans AGAIN! What car do ya Run Frank? I might come down. I live 14 miles north of the track
