Wow - 2 atmospheres. That's not your average engine. (115% trapped mass VE @ peak HP rpm.)Stan Weiss wrote: ↑Wed Oct 03, 2018 11:47 pmI am sure someone will correct me if I got the calculations wrong.
Bore = 4.155"
Stroke = 3.5"
Rod = 6"
IVC = 85 ABDC
VE = 115%
cylinder pressure around 61.5" hg @ IVC
Stan
Compression Ratio Vs Cylinder Fill
Re: Compression Ratio Vs Cylinder Fill
Plausible. I was imagining some kind of an average engine, and "when the intake closes" is a little hard to nail down.
- Stan Weiss
I would be interested if anyone else did these calculations what they come up with.
Bore = 4.155"
Stroke = 3.5"
Rod = 6"
IVC = 76 ABDC (36/76 - 292 seat-to-seat - 110 ICL)
VE = 100%
cylinder pressure around 47.1" hg @ IVC
Stan
Bore = 4.155"
Stroke = 3.5"
Rod = 6"
VE = 100%
Stan
- Stan Weiss
CR = 13.5:1 for both examples.
Stan
Stan
It might be interesting exercise to figure it out freehand by some method, but honestly I never have tried.
There are several engine sims on the market that can simulate the whole PV loop so you can know the pressure at any crank angle you want. No offense intended but I'm getting kind of a weird vibe going on....based on your signature.
1.5-2b depending on rpm send to be what some simulations show
The more I think about it, It's a heck of a trick question. Some kind of riddle. Of course the pressure rises very rapidly with each degree, and when the valve closes COULD be considered negligible since it is at high rpm. If you actually wanted to know when the valve closed you'd have to really define that. It's going to have hit the seat a few degrees before you'd think, but then it's going to bounce, so....when DID it close? But....the low lift flow is negligible at peak power, so, you can functionally ignore it. VE is similarly suspect, as you don't know how much was trapped and how much went through, and EGR %, and is that estimated VE FROM power produced? Or some kind of actual or theoretical...who knows, not to mention temperature.
Just pick a degree that is near when the valve closes, and figure what the pressure was backward from the gross power produced and CR and temp, ( like BMEP estimate).... might work fine, but would that be a suitable answer for..... whatever the question was?
What was the question? That's the question.
- Stan Weiss
A test where no software or expensive equipment needed.
Hook a compression tester up to an engine and do a cranking compression test. This will show what you get when cylinder pressure is just about atmospheric @ IVC. Now if you gauge goes high enough start the engine and see what it reads then and as you slowly increase the RPM.
Stan
Stan
Unless the engine is under load, I believe its peak pressure will be lower than the cranking pressure.
I learned two things when I was a young feller.
1. A 12.5:1 motor that pumps over 150 lbs makes about 60 lbs of cylinder pressure when it's running.
2. Never start an engine on a engine hoist.
I know that's simplistic....but you take your lessons where you can. I learned these things concurrently.
- Caprimaniac
Mark, you don’t have a video of that engine in the hoist, do you?
Does the start of compression mark the end of the intake process? It doesn't necessarily occur at the same time as IVC. Engine speed determines the point at which the fuel/air mixture stops flowing into the cylinder. At lower RPM, the start of compression is closer to IVC and farther away as RPMs rise. How do you calculate for that?
What is the projected compression pressure ?Stan Weiss wrote: ↑Thu Oct 04, 2018 10:54 am I would be interested if anyone else did these calculations what they come up with.
Bore = 4.155"
Stroke = 3.5"
Rod = 6"
VE = 100%
Stan
