Brake in procedure
Re: Brake in procedure
GT 50 wanted to make sure you fully understand what i was saying about the seat the rings deal. Accelerate from 2000 or 2500 to 4000 rpm's then completely back off the throttle, decel back to appx. 2000 then repeat. No need to push to WOT especially if you are using a carb. which would dump maybe excessive fuel on the rings. Hope this helps ! Mark H.
Cjperformance said all that needs to be said!
