connecting rod fastener locking device
Does any current automotive or bike engine, or aftermarket racing parts, use any sort of locking devices on the rod bolts or nuts?
Re: connecting rod fastener locking device
Does any currently used automotive or truck engines, use any sort of locking devices on the rod bolts or nuts?
99.5% no
I wanting to think I seen something that had the rod nuts cotter pinned. I can't remember what
Puzzling when you think about it. For most of the first hundred years of the IC engine, lock nuts or cotter pins were used on many rod bolts. Now not. What's changed?
All I can think of is that perhaps the yield strength of modern fasteners has increased bolt stretch enough that friction torque reliably resits the Murphy Force.
I remember when some con rods had these on the nuts as a safety lock. I used them as a lock nut on the chevy V-8 rocker arm nuts
There was a persistent superstition that if you didn't eat enough garlic and properly dance around a tall pole in the spring, Black Pete would loosen your rod bolts during the winter. He used instant frost to instantly cool the rod from the outside, and loosened them by hand. Thus locknuts, safety wire or cotter pins or staking were used to thwart him, as he didn't carry a wrench.
Once loctite was invented, they used that.
If you don't believe in santa clause, then you surely don't have to worry about it.
- af2
Before bearing crush yes. Since then no.
GURU is only a name.
If a rod nut comes loose a pin or pressed metal lock nut is not going to do much.
If you used a sturdy lock nut to lock both nuts together on the thread you then make another problem, the clearance between nut and bolt thread is taken up forcing the 1st nut off of its supporting thread face, this adds a little stretch to the fastener (but this can be accomodated for) and shifts the bolts main load point out to the thread faces of the 2nd (lock) nut. If you then have a fastener failure at this lock nut tension point the fastener stretch is reduced, clamping force lost etc, it all takes a dump anyhow.
There is a very effective and proven rod bolt retaining device. It's called a properly torqued rod bolt with proper stretch. Been used for a long time and seems to work well in millions of engines! Use these and you wont have any problems when properly installed.
Yes, I did see an engine once that used cotter pins on the connecting rod nuts. It was a 1920's Continental engine, four cylinders about 5.50" bore, 6 inch stroke and weighed about 1200 lbs. Application was an old Adams road grader and maximum RPM was about 2200. Up-draft carburetor, magneto ignition and it was started by hand cranking.
Bill
SAE Member (30 years)
X-actly !Newold1 wrote: ↑Wed Jun 20, 2018 10:20 pm There is a very effective and proven rod bolt retaining device. It's called a properly torqued rod bolt with proper stretch. Been used for a long time and seems to work well in millions of engines! Use these and you wont have any problems when properly installed.
The first car I raced and rebuilt used a thin steel locking tab that spanned the rod cap, you bent tabs up against the flats on the bolts.
It was a Triumph Spitfire Mk 1, here's diagram, part 104642
https://www.canleyclassics.com/triumph- ... d-camshaft
Those were abandoned with the Mk II model, and I always used a tiny dab of Loctite Blue on the threads instead.
Yes, I realize today that Loctite will change the fastening torque for full tension compared to dry or lubricated.
But if you use the bolt stretch method, fastening torque is no longer an issue.
I used solvent to clean the threads.
