How much cam is too much?
rdkonkel
Post by rdkonkel »
Building a 9.5:1 sbc 406, afr 220 heads, edelbrock dual plane intake, 1-3/4 headers, 750 holley, in a street el camino, (no racing just street bashing)
I want to get the most driveability and still have good horse power. Will limit it to 6,000 rpms (so it lasts longer)
Question: how much cam can i use? I know most will recommend a 1,000$ roller but is it that mych better than a good hydraulic flat tappet?
Or have the rollers evolved so much that you can use a high lift and still be streetable?
(No gears/stall in this car. But 4 speed auto with low first gear)
mag2555
Re: How much cam is too much?
Post by mag2555 »
For a all around fun street drivable car with your cid and heads I would not go over 225 duration @.050", with a lift of .500" with 1.5 rockers.
With a Cam like this if you find you can deal with more Cam for more power then you can then step up to higher ratio rockers for more lift and duration.
rdkonkel
Post by rdkonkel »
It’s been along time since I’ve had a Street motor that wasn’t an LS. I built a 355 with a 488 lift thst was a dog 20 years ago, and currently have 6.0 in my truck with a 617 lift
Cam with great low end power. Can that be accomplished on a small block Chevy ?
lefty o
Post by lefty o »
you can definately make low end power, imo your looking at something in the 230degr range and about .525" lift with a flat tappet on about a 108lc,but honestly id consult with whomever is your favorite cam guy. id consider a hyd roller for what you want, then you can run quite a bit more lift and actually use the heads you have.
67RS502
Post by 67RS502 »
Sounds like a larger version of my 383.
I'd bump the comp some tho.
My cam is 224/224, made 483hp/495tq with a dual plane, daily driver streetable.
With that low a comp I would go over 230s duration.
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
67RS502
Post by 67RS502 »
lefty o wrote: Tue Jun 19, 2018 1:17 pm you can definately make low end power, imo your looking at something in the 230degr range and about .525" lift with a flat tappet on about a 108lc,but honestly id consult with whomever is your favorite cam guy. id consider a hyd roller for what you want, then you can run quite a bit more lift and actually use the heads you have.
More lift? ... and I thought you cant run more then .525" on the street :lol:
Sorry couldn't help myself :wink:
67 camaro
62 Nova cruiser
224/224 HR cam
1.57 10.97 @ 121.2
lefty o
Post by lefty o »
67RS502 wrote: Tue Jun 19, 2018 2:17 pm
i know, some people just cant help themselves, but he was asking about a flat tappet, so i based a recommendation on that!
rdkonkel
Post by rdkonkel »
Is that hydr roller?
Post by PackardV8 »
In a strictly street car, torque you can use all the time; top end horsepower, seldom-to-never. Too much cam takes away more in driveability, low fuel economy, low vacuum, short guide and spring life than it gives back in usable performance. Stay away from the ragged edge of lift and duration. You'll be glad you did.
And yes, agree with Chris; for strictly street, consider the 195 heads. Again, more of everything you can actually use.
Just an hour ago, I was creeping through stop-and-go traffic alongside a '39 Chevy coupe with a BBC tunnel ram, too much fairgrounds cam and some type automatic transmission. He was lurching along dragging the brakes, smelling rich, bucking against the converter when stopped. Didn't look like a fun ride to me.
BigBlockMopar
Momentary Specialist
Post by BigBlockMopar »
I'm reading stock stall convertor right? Any power brakes?
Mopar Performance used mention that their 284 adv. dur. Purple cam was roughly the largest cam that could be used with a stock torque convertor.
I think they were fairly right at the time.
user-30257
Post by user-30257 »
cstraub wrote: Tue Jun 19, 2018 5:10 pm 383 pump gas with that camshaft and AFR195's OTB
That should be great on fuel economy ;)
user-30257
Yes, those 220 cc heads are just WAAAY to big, it will lose so much down low power you won't be able to drive it. Even with the 23 extra cubes.
If I were you I would get some 195 and full them in till they're about 160cc.
Then when you want to go faster you can grind them out to 230cc
GARY C
Post by GARY C »
Headguy wrote: Tue Jun 19, 2018 8:31 pm
How would it effect it?
How do you increase fuel economy and hp at the same time, doesn't it normally require more fuel consumption to increase hp?
Surely your not just trying to create drama on a tech thread as opposed to just answering the OP's question?
Dry humor is occasionally a feature of Headguy's posts... :wink:
(The wink emoji is a clue.)
GARY C
Post by GARY C »
MadBill wrote: Tue Jun 19, 2018 8:54 pm Dry humor is occasionally a feature of Headguy's posts... :wink:
It appears to be a way to take a jab at specific people while not having to actually post anything of relevance to any post he is involved in or maybe that's just a coincidence that has got him in timeout before?
