Vacuum leak add power
RCJ
Post by RCJ »
If you have a restricted carb because of rules can you use a vacuum leak to add some power?
Brian P
Re: Vacuum leak add power
Post by Brian P »
I know it's been done ...
It depends whether the organizers wise up to it and write the rule in a way that prohibits it and which they can enforce.
DrillDawg
Post by DrillDawg »
What is the restriction, carb size or plate.
BORN RIGHT THE FIRST TIME
wwmtlineman
Post by wwmtlineman »
Worked back in the late 60s for NHRA stockers until they caught on and used a sniffer to check them. A lot of 2 barrel cars slowed down after that. They would idle around in a black cloud of rich mixtures
RCJ
Post by RCJ »
Carb , but how would a plate be different?
Fireonthemountain
Post by Fireonthemountain »
wwmtlineman wrote: Fri Jun 15, 2018 11:51 am Worked back in the late 60s for NHRA stockers until they caught on and used a sniffer to check them. A lot of 2 barrel cars slowed down after that. They would idle around in a black cloud of rich mixtures
3 deuces cars used it as well then. I have thought of other leaks that might be beneficial in a similar way without changing or raising idle mixtures. My head is still stuck back then in many ways, in my thinking.
pamotorman
Post by pamotorman »
put on a fake vented inside the car power brake reservoir with a vacuum line to back of the carb base. you can close the leak inside the car for tech inspection.
pamotorman
Fireonthemountain wrote: Sun Jun 17, 2018 12:46 pm
just enlarge the power valve fuel feed drilling and it will not affect the idle richness as you are only looking to richen up wide open throttle.
Fireonthemountain
pamotorman wrote: Sun Jun 17, 2018 6:09 pm
Or have the leak above the blades.......
shiftbyear
Post by shiftbyear »
I read an article some years back of a nascar team that got penalized for running hollow intake manifold bolts, the bolts were also drilled just under the head to provide an airpath. Desperate times....
