Max out of the hole
sccagt1racer
Max out of the hole
Post by sccagt1racer »
I'm assembling a ls engine for a friend and from my calculations its going to be .012 -.015 out of the hole. I have a .051 head gasket right now and could go thicker if needed. How much is too much out and what is the min quench I'll be safe at. Ive been told .038 -.040. Its a ls6 with a wiesco forged piston. wiesco 6.125 rod and stock crank. Its going to see a max rpm of 7200 road race car.
af2
Re: Max out of the hole
Post by af2 »
Not advanced. You can get any thickness gasket you need. Get it assembled and figure from there.
GURU is only a name.
jed
Post by jed »
I have built several with the piston .012/.015 above the deck and used a .046 gasket with no
Reported problem.
Put it to get her and drive it like you stole it.
John
Post by PackardV8 »
Your combination should be OK.
Are you going to install the limiter chip and a locking tell-tale tach? Never believe a driver or a friend on a race track. They only shift when they're ahead.
Geoff2
Post by Geoff2 »
I am currently building an engine & have deliberately had the block decked so that the pistons are 0.010" out of the hole. 0.039"head gasket. Trying to cheat the octane fairy. Engine will be limited to 6000 rpm.
mag2555
Post by mag2555 »
.015" out of the hole means it will grow to .020" when at normal temp, but if you have Aluminum heads concider it a wash!
houser45
Post by houser45 »
Leave it with the .051”
CGT
Post by CGT »
sccagt1racer wrote: Wed May 16, 2018 6:34 pm I'm assembling a ls engine for a friend and from my calculations its going to be .012 -.015 out of the hole. I have a .051 head gasket right now and could go thicker if needed. How much is too much out and what is the min quench I'll be safe at. Ive been told .038 -.040. Its a ls6 with a wiesco forged piston. wiesco 6.125 rod and stock crank. Its going to see a max rpm of 7200 road race car.
Aluminum block? I have done quite a few that were .006 to .008 above deck and used a .036 cometic..aluminum head, aluminum block LS. Your clearances above will be fine, even if its iron.
Rick360
Post by Rick360 »
mag2555 wrote: Thu May 17, 2018 1:03 pm .015" out of the hole means it will grow to .020" when at normal temp, but if you have Aluminum heads concider it a wash!
Wow, I gotta see the math on that. :-k
Rick
af2
Post by af2 »
Rick360 wrote: Thu May 17, 2018 3:52 pm
Rick
Ya me too. On a typical blown Brad we see .014" growing from hot to cold. HMM If the piston was out it will stay out!
RCJ
Post by RCJ »
I've run 100s of laps with a motor that is .027 out of the hole with a.070 cometic gasket..040 is what shoot for.
af2
Post by af2 »
RCJ wrote: Thu May 17, 2018 4:56 pm I've run 100s of laps with a motor that is .027 out of the hole with a.070 cometic gasket..040 is what shoot for.
Re working a 489 that is using a .061" Felpro and will get the same one at .039" total clearance using Aluminum heads now.
pamotorman
Post by pamotorman »
the aluminum block will grow .005 so you will be .005 less than room temp measurement
There have been a number of S/T threads on ideal piston/head clearance and 0.040" seems to be well-accepted as a good target for iron blocks with steel rods. Most feel ten thous 'too much' is way better than five thous too little, but there are numerous builders that are prepared to fly much closer to the sun; down to 0.030" and even a tad less. :shock:
xanadu
Post by xanadu »
Closest ive gone is .028" on an iron headed ford 351C. Im still scared when i think about it.
