Holley Ultra HP "950" 1.60" v Annular CARB KIT
BradH
Post by BradH »
I have too many carbs! It's time to thin out the herd #2 of 2!
Holley Ultra HP "950" 1.60" venturi carburetor converted to annular boosters in very nice used condition. NOTE: This will be sold as a PARTS KIT to be assembled and tuned for the end user's application!
Although I did test it briefly using different boosters and metering blocks than will be included here, I didn't manage to get it sorted out to my satisfaction. The change in boosters and metering blocks are intended to return it to a more "standard" set of parts from which to tune the new combination.
Included (parts are used, unless noted otherwise):
- Holley Ultra HP "950" 1.60" venturi aluminum main body equipped with new BLP billet 12-hole x .600" ID annular boosters
--> NOTE: Main body has been drilled & tapped for replaceable TSRs (Transition Slot Restrictions)
- Holley Ultra H/XP "950" billet base plate w/ factory-slabbed throttle shafts
- New Holley Ultra H/XP billet 5-emulsion-hole metering blocks with replaceable emulsion, IFR & PVCR circuits and ~ .143" angle channels
--> NOTE: IFRs can be installed in either the original "high" location or in the recommended "low" location that may improve idle characteristics
- Holley Ultra H/XP fuel bowls:
- standard primary & notched secondary floats for jet extensions
- Holley .120" N&S
- alcohol-compatible GFLT accel pump diaphragms
- #6 AN male fuel fittings
Additional parts to help complete assembly:
- fuel bowl & base plate fasteners
- selection of pre-drilled & blank emulsion/PVCR jets & IFR/IAB/MAB/TSR bleeds
- selection of primary & secondary jets that should be "in the ballpark" for initial testing
- new fuel bowl & metering block gaskets
- new stainless steel accel pump discharge check needles & high-flow discharge screws
- .031" "squirters"
- NOTE: No primary power valve or secondary power valve plug will be provided
BUYER MUST EXPECT THAT TUNING FOR THEIR SPECIFIC COMBINATION WILL BE REQUIRED!
The price is $525 SHIPPED to the lower 48 US states. I accept USPS money orders and cash. Sorry, NO PayPal OR international sales.
Due to the nature of race engine parts, this carburetor kit is offered for sale "As Is" w/ no express or implied warranty.
Please PM me here, or text 7-zero-3 - 3-one-7 - 7-nine-8-seven... Thanks!
>> WARNING: SCAMMERS WILL NOT BE TREATED POLITELY <<
BradH
Re: Holley Ultra HP "950" 1.60" v Annular CARB KIT
Post by BradH »
5.7.2018 - Judging by the lack of interest, I'm revising the status of this item as "No Longer Available".
