I have read about head flow for years,But?????
Warp Speed
Re: I have read about head flow for years,But?????
Post by Warp Speed »
Warp Speed
Abbottracingheads
Post by Abbottracingheads »
Airflow is not the be all end all in making power. You need air flow sure, but the runner size and shape and fuel handling is just as important.
Post by PackardV8 »
cgarb wrote: Thu May 03, 2018 7:00 pm Different inches of vacuum....heads are flowed at 28" and I believe a carb is flowed at only 10" or less.
IIRC, 4-bbl carbs are rated at 1.5 inches of vacuum and 2-bbls at 3".
Carnut1
Post by Carnut1 »
PackardV8 wrote: Thu May 03, 2018 8:56 pm
What do they flow a single throttle body at? Thanks, Charlie
cgarb
Post by cgarb »
I'm just saying that if you rated a carb at 28" the cfms would be a lot more than what they are rated at. What would the 300 cfm intake port flow at 1.5" of vacuum? The restriction is not at the carb because the intake isn't drawing all 8 cylinders at the same time. I didn't quite understand the point you were getting at regarding a 300cfm intake port and 800 cfm's at wide open. Not arguing I'm just trying to understand.
modok
Post by modok »
Sinc he has a supercharger it should be real simple.
The runners are short enough you can just go by size. The carb needs to match the draw of the supercharger.
Carnut1 wrote: Thu May 03, 2018 9:01 pm
1 bbls carbs were also rated at 3.0" Hg.
EFI throttle bodies are a relatively recent development (compared to 1 or 2 bbls.) and with no fuel mixing duties, can be sized for less WOT restriction, so regardless of barrel count (3 on the 1990-95 Corvette ZR1...) an aftermarket manufacturer would almost certainly rate them at 1.5" Hg.(20.4 H2O).
OEMs? Who knows unless they list it...
Stan Weiss
Post by Stan Weiss »
Warp Speed wrote: Thu May 03, 2018 6:39 pm Why does a port need to flow 300cfm, when the engine running full song doesn't pull 800 total?!?
Jay,
How much will that port flow in 3 Milliseconds?
Stan
Warp Speed
Stan Weiss wrote: Fri May 04, 2018 12:01 am
Jay,
Stan
Kinda my point...........I think?!? Lol
digger
Post by digger »
What's the size of the hole ...
JohnsnsFord2@aol.com
Post by JohnsnsFord2@aol.com »
You need velocity
Stephen Johnson #2162
Horace Johnson #2167
SS/D 427 Ford Fairlane NHRA-IHRA
Ex-Jim Van Cleve
1985 Mustang GT N/A 331
user-23911
Post by user-23911 »
The CFM that an engine consumes at X RPM is one thing.
The CFM that a head flows at a certain no of inches water is something completely different.
As is the no of CFM that a carburettor flows at x inches Hg,
3 completely different things with nothing in common apart from "CFM".
barnym17
Post by barnym17 »
Isn't the carb rated in inches of mercury vs cyl heads in inches of water (i.e. using manometer) the numbers would all have to be taken at the same depression, using the same measuring device to in any way correlate the cfm of the carb vs the port.
barnym17
Post by barnym17 »
Sorry I just saw Joe mentioned the same thing I did.
