yup.lolgroberts101 wrote: ↑Tue Apr 10, 2018 10:16 amWhy do you say that? Because you "sigh" everytime yiu see one? LOLMTENGINES wrote: ↑Tue Apr 10, 2018 10:11 amits a sigh groove..lolgroberts101 wrote: ↑Tue Apr 10, 2018 10:11 am
No doubt.
What's with the big gash, if that's what it is?.. in the fire deck above the intake valve?
Potential of ported Edelbrock Performer RPM’s 6025’s
Re: Potential of ported Edelbrock Performer RPM’s 6025’s
Obviously don't know what part of the country you are in but most likely there is a good cylinder head man or shop with good performance cylinder head abilities around you.
As others here have said, those heads need some pretty important work and parts, so put together an idea (budget) of what you CAN spend and see if its worthwhile to get into all they really need. With the intake at that exposure in the head they have been milled a lot and maybe even angle milled. If that gash in the deck is real then they are going to need additional milling and if that's the case they are just about junk in my opinion. If you are building something where you need a particular cfm flow then also make sure they are flow benched to make sure they what additional porting they may need and you should cc the ports and chambers to see where they are at now.
I would not advise just using them on a engine without some real careful look over!
Sometimes parts like these can be more expensive with all the rework needed than it would cost to buy a ready to run pair that can perform up to your needs. JMO
Sounds good. Thanks to all for the good advice. I might just sell them especially if they need work on the deck and other places. I am an amateur enthusiast and don’t know that much about head work.Newold1 wrote: ↑Tue Apr 10, 2018 10:48 am Obviously don't know what part of the country you are in but most likely there is a good cylinder head man or shop with good performance cylinder head abilities around you.
Looking at that chamber again promp's me to think that the intake seat was re-cut for a 2.08" valve.
Those heads appear to have had a terrible former life or two.
what happened to porting the cleveland heads and building that?
There on the back burner. I still have them but am not sure o want to mess with the heads because the whole M code engine, intake to pan, is all stamp dated within a week of each other so might sell to a restorer of a 70 mustang or Torino. They’re all 12/69 date.
I’ve got both a set of N351 & n352s to make a fast motor out of. I haven’t done much of anything though. Been busy buying foxbody coupes the last two years.
I agree after zooming in, can clearly see two angle, inner one looks like a 45 and out like a 30-35. If thats the case it won't fit and have enough working clearance, that might be why 2.02 are in it instead. Pictures can lie though. Theses heads work good, just dont do very much at overall. .Bigger is not better with these heads. ButChamber smoothing and sizing bowl to 90 percent and making the Short turn like will be important as opening bowl will change/hurt SSR if not rolled at least like factory. A perfect round SSR will get ya in the 250 cfm pretty easy but fall at .550 lift. Pinch is big enough , dont open much if you do. There springs are weak from factory, get some new ones for sure. Looks like the gash just missed the fire ring. Take apart and have someone check guides/seats and port work. might be better then it looks. I wouldn't guess.
I understand. 20 years ago when I hurt a couple pistons in my 93 I bought an early 302 block and crank from a friends dad who was a big ford guy. It was a virgin bore 1970 boss 302 block and matching forged crank. I was going to use it for a performance build. But when I looked up the serial numbers on it I found that the car was in missouri. So I offered it to the guy who had the car. He was happy to get it. I dont have any regrets because I didnt throw a rod through very rare block and at this point I have a block that makes the mains in the original boss 302 block look like origami. The profit I made on it wasnt bad either.thomas butt wrote: ↑Tue Apr 10, 2018 2:27 pmThere on the back burner. I still have them but am not sure o want to mess with the heads because the whole M code engine, intake to pan, is all stamp dated within a week of each other so might sell to a restorer of a 70 mustang or Torino. They’re all 12/69 date.
Not to mention that the N351 can make power.
