Making an intake runner thinks it's longer?
digger
Re: Making an intake runner thinks it's longer?
Post by digger »
Less taper makes act a bit longer
LSP
Post by LSP »
427dart wrote: Thu Mar 08, 2018 10:00 am Let's say you have a tunnel ram type intake manifold that has runners shorter than you want for a particular RPM/ HP range.
Say for example the runner is 6 inches in length and results in power range from 5000-7500 RPM.
Would adding a divider about .090 in thickness and 4 inches in length centered in the runner speed the airflow up thus moving the power range down
to 3500-6500?
Just one of those "what if" ideas!
The 4" longer intake tract will have a power range of 2350 rpm less.
In-Tech
Post by In-Tech »
Make some custom reed valves between the intake manifold and head port entry.
-Carl
groberts101
Post by groberts101 »
In-Tech wrote: Sun Mar 11, 2018 5:26 pm Make some custom reed valves between the intake manifold and head port entry.
And when you figure that kinda deal out let me know. I'll have the cash ready. :D
In-Tech
Post by In-Tech »
groberts101 wrote: Sun Mar 11, 2018 6:23 pm
Figuring it out and making it work is one thing, making it live is a whole 'nother. :shock: :mrgreen:
-Carl
I've seen the parts for experimental reed valve systems for a pushrod V-6 and ditto a V-8 but neither made it out of the lab. I think Alfa Romeo produced a reed valve 4 stroke.
In-Tech
Post by In-Tech »
I brought it up because a lot of good ideas need development to make them work and live. Keeping the mass flow increasing in a tapered runner is easy, getting it started is hard. The reversion is the biggest thing that makes a "large" port act lazy. If you can get the same mass flow into the cylinder a thousand rpm sooner because of a reed and it loses loss of mass flow a thousand sooner than its original peak, isn't that what we are talking about? \:D/
-Carl
