SBC Dyno results, where to go from here
BrazilianZ28Camaro
Re: SBC Dyno results, where to go from here
Post by BrazilianZ28Camaro »
rustbucket79 wrote: Sat Feb 10, 2018 1:27 pm
My 10 bolt (8.5) has a Strange spool, 33 spline axles, c clip eliminators, TA cover and bearing cap studs. Is that the setup you run? What brand of gears and ratio? N/A or power adder? Tranbrake? Stage RPM? 60’ times?
I would love to throw a set of 4.56’s in the car but I am concerned about breaking a gearset and messing up a $4000 transmission 🤬.
Looks like your axle is plenty strong already. When my rear axle suffered wheelhop off the gate ( bad track prep plus overpowering the stock leaf springs #-o ) the ring gear let go but the pinnion was ok. Yes the TH350 first gear broke too. Was a foot brake launch.
I do believe a 456 pinnion will take your engine's power, just avoid wheelhop.
Have you a T brake?
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
rustbucket79
Post by rustbucket79 »
AFR 245’s, ports definitely larger than the tunnel ram I used. (Didn’t bother to port match the intake)
TH 400 with brake, have launched from a 5400 2 step on a well prepared track. (You know you have good traction when a 6000 stall feels like about 500 short 🤣
BrazilianZ28Camaro
rustbucket79 wrote: Sat Feb 10, 2018 6:16 pm AFR 245’s, ports definitely larger than the tunnel ram I used. (Didn’t bother to port match the intake)
Thats tells a lot about the powercurve we saw on the comparo graph you posted IMHO.
Holly cow! :D
And BTW you don't need to cut the hood to use a T-ram, just pull it off.
NEW BEST ET
F-BIRD'88
Post by F-BIRD'88 »
Ha Ha Ha I like that. :notworthy:
BrazilianZ28Camaro
F-BIRD'88 wrote: Sun Feb 11, 2018 12:14 am And BTW you don't need to cut the hood to use a T-ram, just pull it off
Open the link in my signature and you will see why I wrote that 8)
Sorry for the little Hijack OP.
NEW BEST ET
340king
Post by 340king »
The good news is that there's performance available at relatively low cost, I think you could pick up performance by just shifting the first two times at a higher rpm. That doesn't cost much, other than a risk of failure and some added stress to the valve train. The other good news is that if you don't change it too much, missing a shift point will be no big deal. That flat HP curve? is nice to have.
I agree with the larger stepped headers. I tested a couple of sets once and there was 15 HP difference between the two pairs. Both were 1-3/4" stepped to 1-7/8" long tube headers. The upswept ones with nearly a straight shot out of the port were a little longer and made more torque, while the crossover curved upswepts made more HP. I had anticipated that the straighter headers would have been better, even though they were a little longer. That's why we test things!
